Thread: G64 intake manifold swap question
Showing results 1 to 6 of 6
    00GalantX
    My intake manifold just split on my 4G64 like it was made of plastic, and i've been searching for a replacement/reliable intake. Another stock g64 intake is out of the question, it's too unpredictable. An 200? outlander intake would been fine but finding one is my problem. Also i was looking at the 9g galants manifold gaskets, they are the same as the outlander and 8g galants gaskets, will it fit??
    If not what specific years of outlander intakes will fit.
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Try looking at car-parts.com
    Go for an 03 Outlander intake manifold and make sure that the trottle body comes with the outlander TPS and IAC. Also you need the throttle cable from an outlander...everything else just swich onto the outlander intake manifold, and try rocker auto parts. They make it simple to order parts and gaskets from there. Goodluck
    05-25-2006
    New York City
    1,028
    I've done the swap b4. All you need is the manifold, tb with sensors and a new manifold gasket. 2 problems you will run into is extending some vacuum lines and you have to make a small bracket to secure the dip stick. I purchased everything from some spot in cali called ms recycling. It came out to about $450 shipped. That was about 3 years ago. Prices might be lower now.
    2000 Galant ES = Daily Driver
    12-02-2008
    1,263
    Quote Originally Posted by Sleepervr-4 View Post
    wow yeah thats pretty high price there...I only spent no more than $220.00 and thats everything together.
    Just keep looking around and you will find stuff alot cheaper
    dont know were you live but i have an oem manifold if you need it till you get the new one i'm just going to junk it anyhow just let me know
    PrityG-lant03
    Will that outlander intake manifold and tb add horsepower?
