Go to our Tutorial section.....
I've been looking all over the place and i can't find a complete list of the parts i need for the 4g64 ti 4g63t head swap..can anyone give me the full list plzzzz????
And also can i use any 4g63t head from any year for this swap on my 03 4g64 long block???
Only EVO VIII heads from mitsu, JDM EVO heads work but if you need a part probably your going to imports it from japan and its going to take a while,
also you can use 99-03 sonata or 00-05 kia optima heads.
Search for DOHC and you should find the info, also look on club3g.com
4g64T 5spd
yea when i did my swap i managed to find most of the info here but really nothing complex about this swap its really straight forward.
2002
4g64 dohc turbo 5-speed
gt30r @20psi stock block,mbc
2.5" tbe
evo 8 ecu and maf
ok..how will the evo8 ecu work since i have a automatic tranny???
go to search and type dual ecu read johnathangalants tutorial it will help with anything you want to know about ecu setup although if your still n/a i think the evo head runs fine with our stock ecu though im not 100% sure youd have to ask some1 whos tried it.
2002
2.5" tbe
evo 8 ecu and maf
Can i use OE rods and pistons for an Evo 8 for this swap?
the rods should be the same length but the pistons on the evo wont work i believe they are a bit smaller then ours but the rods are the same from 4g63 to 4g64
2002
2.5" tbe
evo 8 ecu and maf
Evo pistons wont work as the bore size on our motors are bigger you would have to get search around for piston made for a 4g64 with a 4g63 head, i think wiseco makes them as does j and e.
Check this thread:
http://forums.evolutionm.net/evo-eng...ck-thread.html
1st post states Evo motor specs and 2nd post give you an idea of the 4g64 with evo head.
4g64T 5spd
how are 4g64 and 4g63 rods the same when the 64 has a longer stroke? differnt crank?
I have about $10k into my engine setup, including engine, turbo, manifolds, cooling system, fuel system. My engine is built, all upgraded internals.
4G64/63T
AEM EMS
wow..thats hella money
