Thread: Evo swap into a galant?
Showing results 1 to 3 of 3
    UnforgivenAutoSports
    Is it possible to Evo swap into an 01 galant? I've heard some people doing it but would it be cheaper to just get galant parts or evo? Thanks guys
    08-04-2003
    NY
    4,344
    If you do some searching on here you will find the info you need. In short, yes its possible, if your looking to make it AWD your going to need EVO and 2g dsm parts, if your looking to make it FWD you need an evo engine with the accessories/pumps, etc, EVO ECU, you need to wire the harness to the EVO pinout and you SHOULD swap the car to 5 speed and an aftermarket LSD.
    99' Galant ES
    4G64/63T
    AEM EMS
