Welcome to the site. Those are impressive numbers on a stock 6-bolt bottom end. I didn't think it could handle that much without grenading. I moved from a 1g Talon to a Galant but I used a 2g Talon as my donor for my project. Both 2g/7g Galant harnesses use clips under the dash to connect the body/gauge wiring with the engine bay. Most guys just rewire the Galant harness to work with the 2g ECU. It just requires adding a few wires and moving a few others. You'll find plenty of info on the 2g ECU swap here on the site with some searching.
