Thread: 42 offset
Showing results 1 to 3 of 3
    42 offset
    will 18x7.5 in a 42 offset fit my car?
    J. T. Z.
    No problem as long as you stay with a 40 series tire and don't go below a 2-2.5" drop. If you don't have a drop then you will have no problem what so ever. I have 18 x 7.5" Giovannas with an offset of +38. I have a 1.5" drop and there is still room. Check out the link in my sig for pics.
    Tiller
    should fit fine... that's what i was going to get, but ended up with a 44mm anyhow...
