yea, im right around 3000-3100 rpms at 70mph
Light em up.
Hmm, mine revs around 2700rpm at 70 without the A/C. 3100 rpm sounds a bit high.
bsilver23, I'm jealous of your extra gear!
Results are in!
I traveled 318.2 miles from the last time I filled up to the top and then I refilled the tank to the top again with 11.225 gallons so that puts my MPG at 28. But that's also ~90% freeway miles. I'm happy because I expected it to be an avg of city (21) and highway (27) so I would've been happy with 24 but I guess 4 more miles doesn't make that big of a difference. At least the car is running well.
And just because I like stats... the last time I filled up was 7 days ago at almost the exact same time so I traveled about 45.5 miles a day on average.
Any one else want to post theirs?
wow that's great..the highest MPG I had for the city was 22 and the highway was 29.. where do you live? bc I know out here in vegas we now have a lot of stop and go traffic my last fill up dropped down to 22.08 mpg. My overall MPG is 21.94 mpg based on my Road trip app
The 0ne & 0nly King D
the v6 tb will help with the fuel milage if you can keep your foot out of it lol. I just installed mine today, and it tachs at roughly 2400(our tach isnt the most accurate and precision0 at 70mpn, that is a 300 rpm drop=less fuel needed
The lowest calculated MPG I ever got was 18 because I was stuck in traffic averaging 5 miles per hour for 10 miles.
The highest I ever got was 39 using "hyper miler" techniques by tailgating a truck. I'll never do that again. Completely unsafe.
Our cars can easily get higher than 30MPGs if you use your brakes less on the freeway. So when you're on the freeway and you see a reason to slow down (like a slow car entering the freeway) instead of using your brakes to slow your car down, just let off the gas and let your car do the slowing down for you without the breaks. Just make sure you have enough distance to not crash into the back of the other slower cars.
lol maaaaann i miss my good gas mileage you guys suck XD i still remeber 1 week when my i got 6.5mpg....right now im probably around 15-18 if i can ever get it running again.
2002
4g64 dohc turbo 5-speed
gt30r @20psi stock block,mbc
2.5" tbe
evo 8 ecu and maf
I live in WA state. I think since it's getting colder that could've helped the engine run closer to peak efficiency. I actually bought a v6 tb from someone here on the forums for like $50. I took it apart to clean it one day and got lazy and never put it back together. When I moved I decided to just trash it. I should've held on to it because I just wanted it for performance.
Right now only mods are ram air and I chopped off my mufler. No muff could've helped me with mpg since it's less restrictive but I could've swore that the ram air would lower my mpg since more air is flowing pass the MAF sensor it would make up for it by squirting more fuel. Hm.
I've been running the acar app on my phone and it says I average about 27 mpg, we drove from san antonio to san angelo ( about a 3 hr drive ) and used only a half tank.
02 Galant GTZ stock
00 S10 Bagged on 20's Suicide Doors 5 link and control arms, more to come!
