Thread: Starters
Showing results 1 to 6 of 6
    Starters
    Do all automatic 7g's, 94-97 Galants use the same starters?
    Member allrice4g64's Avatar
    02-08-2010
    hager city, wisconsin
    330
    im pretty sure they are the same my car is a 5 speed 7g and my starter im using is outa a automatic. like 95 percent sure its the same.
    2.4 dohc turbo, 10 psi,small 16g, evo 3 02 housing,98 flashable ecu,maft,3inch magnaflow exhaust,aem wideband,blitz turbo timer,egt gauge,balance shaft delete,a/c delete,battery in trunk,arp headstuds,fmic,mbc, (Wiseco 8:7:1 pistons coming soon.)
    08-13-2008
    Waterbury, CT
    3,331
    all automatic starters are the same. the manual starter is different as if you look at the teeth on the 2 starters are different length and be careful for the auto starter to wear done the teeth on your flywheel
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    Ohh trust me I've had this happen already. It was horrible!
    12-18-2008
    Central Kentucky
    805
    I was told by a local junk yard that a starter out of a neon would work but I don't know personaly. I didn't buy one from them though. But I would think that they would be the same from any auto 7g galant.
    Bronx NYC (reppin)
    3,489
    If you need a starter drop me a pm
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
