Thread: Limited slip differential for the 6G75 AUTO
Showing results 1 to 4 of 4
    I have fitted a Quaife QDH7B ATB limited slip differential to a 6G75 auto.
    It involves machine work to make the stock crown wheel fit the Quaife, a small shim spacer, re-machine two driveshaft splines from 28 spline to 27 spline, then case re-harden the splines.
    definitely some good advice.
    TGC Regular Da_Prodigy's Avatar
    01-29-2010
    Elgin,IL (Chicago Suburbs)
    593
    Lmao!!!!^^^^
    10-05-2008
    Grand Rapids Michigan
    1,141
    x1000000 LMAO !
    But on topic thats dope !
