When I first got the G, that was my case also. There should be to metal brackets screw to the radio on each side if there isn't, then you cant mount it. those brackets will have a spot for a screw way in the back and two tabs to slide into the dash upfront behind the wood bezel.
You need those brackets other wise you will have to trim the opening on the bezel to fit an aftermarket radio, by putting the sleeve in and then the radio slides in the bracket, but of course much easier to steal. maybe look into an alarm while your a the audio store
