Nothin guys?
I have an 02 Galant with the factory Infinity sound system. A few years back I had an aftermarket deck installed and found that my tweeters and center channel aren't working. As far as I know they've never worked once the deck has been installed. I took out the deck and looks like everything is correctly hooked up. How do I know which wires are for the tweeters/center? Seems like all the wires that come from the door's to the deck area are all red and black. Thanks for the help guys.
That's the thing. They are wired to other speakers.
x2. You need to find the center speaker wire that goes to the amp and rewire them to head unit or aftermarket amp.
Where is the stock amp located?
under passenger seat.
Alright I'll try and do something and get back to you all. Thanks for the info fella's.
Got them working. Go ahead and close the thread. Thanks guys.
Sound's a lot better. It's not a crazy big difference but it's noticeable and a lot better. If you need help figuring out which wires connect to what let me know because I just did mine few days ago and surprisingly, pretty simple.
i for example had the same problem.. and i just wired my tweeters to the head unit :) and it works great :D
