Thread: Duh2150 Build
Page 1 of 4 1234 LastLast
Showing results 1 to 20 of 61
    07-16-2006
    Cocoa, Florida
    791
    Icon10 Duh2150 Build
    Engine:
    Kia DOHC
    Wiseco Pistons
    ARP Rod Bolts
    ARP Main Studs
    ARP Head Studs
    Eagle Rods
    Balanced Crank
    BC 272 Intake and 272 Exhaust
    BC Valve Springs
    BC Titanium retainers
    Coated 1mm+ Intake and Exhaust Valves
    Balance Shaft Delete
    Bronze Valve Guides
    Fidanza adjustable cam gears
    Polished Intake and Exhaust
    Evo 8 throttle body
    3" downpipe
    WRX 565cc Injectors
    255ph Fuel pump
    oil feed line
    oil return line
    Evo 8 oil pan
    Transmission:
    5 Speed Eclipse
    Fidanza 8lb Flywheel
    Exedy OEM replacement clutch
    modified Ebay Short shifter
    Brakes:
    Diamante 2 piston front
    Rear disk conversion
    Boost:
    Evo 8 Turbo
    Custom made exhaust manifold
    Evo 8 intercooler
    Evo 8 intake piping
    Electionics:
    Evo 8 ECU
    whatever else i run into
    Future plans:
    to many to list :)
    TGC Regular midnight's Avatar
    04-25-2010
    Springfield, MA
    470
    dohc ftw!!
    11-29-2009
    Chadds Ford, PA
    2,768
    what header is that with what turbo????
    07-16-2006
    Cocoa, Florida
    791
    Exhaust manifold I had made and evo 8 turbo
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Looks good, and that manifold is nice
    4g64T 5spd
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Nice work man, that manifold looks good. I see you got your self the small racing Mishimoto radiator...not bad. I was thinking of that myself but for some reason its not big enough for me but let me know how it goes. Is your motor stock?
    05-03-2007
    Socal/Central Coast
    3,803
    nice! but clean your ish! haha
    so Hyundai DOHC, custom turbo manifold, evo 8 turbo?
    07-16-2006
    Cocoa, Florida
    791
    you guys are nuts I'm working on the list I'll get more pics soon
    from a while back when i was test fitting the pipes
    02-07-2007
    ORLANDO
    1,599
    looks good...cocoa?>>palm bay i wanna see this beast lol
    sweet! looking good bro
    2002 5spd swapped
    under construction.....
    07-16-2006
    Cocoa, Florida
    791
    i ran into a small problem, i have to get the bottom gaskets for the wrx injectors to fit the kia manifold :/ i ran into this problem before when i did the DOHC swap shouldn't be hard but hopefully i can order some new ones? have no idea where to look yet
    Engine:
    Kia DOHC
    Wiseco Pistons
    Eagle Rods
    Balanced Crank
    BC Valve Springs
    Bronze Valve Guides
    Polished head
    Evo 8 throttle body
    3" downpipe
    WRX 565cc Injectors
    255ph Fuel pump
    Transmission:
    5 Speed Eclipse
    Brakes:
    Boost:
    Evo 8 Turbo
    Evo 8 intercooler
    Evo 8 intake piping
    Electionics:
    Evo 8 ECU
    To Finish:
    bigger radiator mishimoto Evo 8 radiator?
    oil feed line
    oil return line
    Evo 8 oil pan
    Nice build. I have them CV Axle Assembly in stock which will DIY later as service garages here charge sky high. Took some tips from your build.
    I wanna be a Billionaire... so freakin' bad...
    07-16-2006
    Cocoa, Florida
    791
    So i went ahead and uploaded some older pictures
    07-16-2006
    Cocoa, Florida
    791
    Before:
    After:
    07-23-2004
    San Diego, CA
    1,496
    Quote Originally Posted by duh2150 View Post
    After:
    omg that is so fucked up. hahahaha
    07-16-2006
    Cocoa, Florida
    791
    hey ill edit it and put a picture there but for now, the camera is dead
    After:
    That was evil! Haha!
    07-16-2006
    Cocoa, Florida
    791
    so... today I took the car around the block and the car threw a knock sensor code, I have the knock sensor just wondering how I'm going to hook it up, does it just have a wire that goes to the ecu and a ground?
    also my tachometer dies out on acceleration and idle, so I probably need a larger power wire from my battery up front
    3rd, the car backfires at like 4k-5k rpm, as soon as I get into the boost, like it blows out the spark I gapped the plugs to .028 going to buy new ones as soon as possible and I think there was 87 still left in the tank but i put 93 in runs better but still kicks (my hypothesis is the knock sensor i was reading another post)
    pics coming up as soon as my gf gets home and gives me my dam camera
    Thats coming out great man!!keep up the good work
    11-29-2009
    Chadds Ford, PA
    2,768
    LMAO, how much boost are you running??, cause cant you use the same spark plugs as an evo? they dont blow spark out
