Thread: Need some help
Page 2 of 2 FirstFirst 12
Showing results 21 to 34 of 34
  1. #21
    Well I did block the icv.
    Well start the car, samething.
    Check engine light comes on when i press the gas.
    It seems that the engine is getting too much gas.
  2. #22
    I'm thinking about this part,e8t00171 .
    It's called engine control relay.
    I'll scan the car tomorrow and see what the problem is
  3. #23
    Well didn't scan the car yet, but the engine control module is ok.
    I've changed it and same thing.
    I think now that the ecu is fried.
  4. #24
    Ok guy i really need some help on getting my car back on track.
    I have a autoxray system, I scaned the car, but it tells me that cannot reed nothing.
    I saw in menu that obII 1996 to present, but this engine and computer box is 1994, so I think that's why it doesn't reed.
    A friend of mine came with another scan system, and it scanned.
    mass air sensor,tps sensor, water temp sensor and idle control valve, came on the screen.
    Iput a new mass air sensor on, a tps sensor,water temp sensor from a running car of a friend of mine
    But still the same problem....I didn't scanned it back tho to see what's going on.
  5. #25
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    you have to reset the ecu after making changes to it.
    Build Thread
  6. #26
    how do you reset?
    just take the batt cable?(did it already)
    I didn't know that my friend wrote the problems on a paper.
    I found it today in my car.
    vaf,iat,tps,iac,temp sensor,aps
    The only thing that i didn't check is the egr.
    Can the EGR cause so much problem?
  7. #27
    Well, problem solved.
    The ecu was the problem, something in it has fried.
    I took it to a electronic repair technician and he fix it for me....
  8. #28
    Quote Originally Posted by microgalant View Post
    darn, can i ask how much would that cost.? is it also hard to find some of them as surplus parts? my friend waited for ages to just find an ecu since its a very hot item here in my area..
  9. #29
    Well galant with problem again...
    Last week the car just died with me on my way home.
    Found out that the fuelpump got stock..
    So I put a new one in, after 2 days problem again...
    Check it out, what do you guys think?
    Injectors ??
    http://s177.photobucket.com/albums/w...t=MOV05576.mp4
  10. #30
    Today I took the injectors they clean them for me, went home put them back, and start the car.
    It started and runs fine, the engine runs for about 10 minutes...
    Went for a test drive, put the car in revers and bam, start to work bad again, same thing.
    Maybe there is a loose wire??
  11. #31
    09-20-2007
    Sea Isle city, NJ
    4,098
    dude, i see the car runs fine and then the check engine light comes on and it starts running like crap. See what the CEL is for? W/o that its just shots in the dark
    Build Thread
  12. #32
    Mko I didn't check for cel yet< cause my friend didn't get a chance to check it for me.
    Today I started the car just started fine runs fine, check engine light came on, but the car keep running fine, went for a test drive, runs fine.
    Got back home, turn the car off, start it back, runs fine, than again began to missfire and died
  13. #33
    Seth I've checked the alt fuse, it is ok, the car starts but idles very very bad.
    When I rev it,it blows black smoke out.
    When I turn off the fuelpump, the engine begin the idle smooth.
    So it has something to do with too much gas.
    Is there something that control the gas?
    That is a very bad sign! Did you notice the black smoke before your cooling fan wiring mishap? Does the exhaust smell like rotten eggs?
    If this black smoke problem only happened after grounding out your wiring, then you may have fried your ECU. What Seth98esT said about the 80 amp alt fuse brings back a sad time when I once fried an ECU (luckily it was in my brother's honda civic and not some random stranger's car). Check to see if you can read trouble codes off of it. If you can't, or you can but the codes don't make any sense, then your ECU is probably in the graveyard my friend.
    The black smoke and rotten-egg smelling exhaust indicates to me that the ECU is in "limp mode". The broken ECU runs the engine waay too rich and the smell is the end result of that.
    This to me doesn't make any sense. There's no way all those sensors went bad at once. Again, a sign the ECU is fried.
    "Speed never killed anyone. Suddenly becoming stationary...that's what gets you." - Jeremy Clarkson
    1997 Galant ES with '94-95 style front end and '97 style rear
  14. #34
    09-20-2007
    Sea Isle city, NJ
    4,098
    The black smoke is from running too rich. IDK what to tell you, did you swap the fuel pressure regulator and fuel pump relay signal comes from the ECU and the cam sensor.
    Build Thread
