Thread: properly lowering in cities like Los Angeles
Page 4 of 4 FirstFirst 1234
Showing results 61 to 71 of 71
  1. #61
    blue8g
    My stock Civic killed the G IMO
    and my G had tein springs and grippy tires
  2. #62
    an 88-91 civic probably weighs 1000 pounds less than an 8g galant so handling had more to do w/ the weight than w/ the suspension.
  3. #63
    blue8g
    I understand that. I'm pointing out my experience regarding springs on 8g vs. Civic, which is what he's coming from
  4. #64
    05-03-2007
    Socal/Central Coast
    3,803
    how does this have anything to do with this thread?
    EDIT: ohhh didn't see that OP had a civic
  5. #65
    plus you had a DE which means you didn't have a rear sway bar... it makes a big difference.
  6. #66
    blue8g
    that's a good point
  7. #67
    05-02-2008
    Hacienda Heights, CA
    3,014
    Quote Originally Posted by Kamikaze View Post
    As you probably guessed, I'm not the average grandpa driver, I'm not a crazy ass driver 24/7, but when I do speed, swerve, and high speed corner, I like to be confident and know my machine can handle it.
    you have to get to know your car. ask Racenos and Ivory_G how i handled my car with just stock suspension and heavy chrome 19's lol
  8. #68
    I know 8/3g guys like them, from everywhere else I hear negative stuff about them.
    They're fine for a cheap coil-over set-up. I wouldn't buy them but that's just me.
    http://www.vividracing.com/catalog/v...e-p-14421.html
    Would want if I still had an 8g
    You wouldn't buy them???? Is that why you asked me how much I wanted for mine when I was thinking about selling them?. Megan's are not garbage. Mine have a ton of DD miles and 5 track days in them with custom stiffer rear spring rates and they are just now starting to blow in the rear. The ride does not bounce unless I hit a massive bump and then the rear will bob for a second or two and then settle. Its all about setup preload, dampening,ride height even camber and toe affect it. I hade agx with eibach springs before and let me tell you you can make the ride coilover stiff easily if you set them to 4
  9. #69
    blue8g
    Quote Originally Posted by greddy View Post
    I wanted them for dumpedness
  10. #70
    I agree. I know lots of people adjusting em the wrong way and then complain about bouncing and so on. All 4 of mine has no pressure in the shocks so now it bounces like hell since the G is resting on the springs only
    And i just found out that my K-Sport set has lasted for about 80.000km as a daily driven car and 4 times on track :D And thats not bad for a "cheap" set of coilovers ;)
  11. #71
    09-30-2002
    San Gabriel, CA
    573
    i have tein ss set at the recommended setting which is i think around 3 inches lower than stock? i dont remember. but i HATE driving the galant to LA.... i lost a sideskirt to a speedbump in chinatown :( felt like i drove over a parking block.
    Your signature is too long.
