Door Trigger
Ok i got my alarm installed and i cant figure out how to install door trigger to the alarm cause the alarm says to plugged the purple to the dome or the door light that says its open and the brown to the door that its says its closed can anybody help cause the doors switch gots two wires
your looking for the accessary on wire and the ground wire
yes the wiring diagram so i can plugged the door trigger
