What kinda of injectors are you running. Are they high impedance (saturated) or low impedance? If they are low impedance, did you install a resistor box? An engine only needs 3 things to start, fuel+air+spark=BOOM. Check each one. Make sure you pump is turning on, check your fuel pressure with the key "ON" and while cranking. Remove one spark plugs and rest it against something metal to see if it arcs. Be careful since you have that crazy sparktech CDI setup, that thing will shock the shit out of you if the arc hits you. Crank have someone crank the car while you check the plug to make sure its firing. How did you wire up the CDI setup? If you wired it up as sequential, the stock EVO ECU doesnt have the capability (as far as I remember) to run a sequential ignition. Make sure your MFI relay is good, you should hear it click as soon as the key is turned to "ON" and again when its turned off. Im just throwing ideas at you, run through it, keep updating this thread and I will keep checking it. Send me a PM if you need something more specific. Lastly, if you think your wiring is wrong, remove the heat shielding so the wire colors are visible and take pics, post them up and I will compare it to what I have.
