Thread: Post What You Did To Your Car or Bought Today!
Page 387 of 538 FirstFirst ... 287337377383384385386387388389390391397437487 ... LastLast
Showing results 7,721 to 7,740 of 10744
  1. #7721
    Finally gonna do a retrofit. I have a brand set of headlights sitting in a box in my attic gonna work on those.
    Sent from my Galaxy S4
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  2. #7722
    Got some dueces for the truck
    Sent from my PC36100 using Tapatalk 2
    Nobody built like u, u desighn ur self.
    5spd swap
    full custom body conversion
    18x9 Works VS
    Big 16g evo3T next project
  3. #7723
  4. #7724
    Chilled with Jigz and BabyG this Saturday. Slapped in that Injen CAI and V6 TB, along with a throttle cable tuck :) Damn that sound is addictive.
  5. #7725
    07-02-2011
    South Florida, by the beach
    1,076
    Finally had time and help to drop the gas tank. Fuel pump wasn't working. Quarter tank of gas is a nice easy weight to work with. Never knew how many hoses were attached.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  6. #7726
    Why did you drop the tank to remove the pump?
  7. #7727
    07-02-2011
    1,076
    Couldn't twist off the black cap through the hole under the rear seat. It wasn't that bad at all. This made it easier to twist that black cap off, for me atleast.
    00 Eclipse RS MT
  8. #7728
    03-16-2010
    Maplewood, NJ
    1,290
    Quote Originally Posted by Black8GV6 View Post
    Really? When I replaced the fuel pump on he 3g, I was able to twist the ring off but I need vice grips. Every case is different though. Good job.
    13 Honda Accord EX 6MT
  9. #7729
    07-02-2011
    1,076
    lol, ya'll making me feel dumb, but I tried and I couldn't get anything that would fit to grip the black ring through the hole. Oh well.
    00 Eclipse RS MT
  10. #7730
    Don't mean to be mean but it was dumb. A hammer and a screwdriver and a few taps would have loosened it right up. Should of checked the fourm it's been done 100+ times without dropping the tank...
  11. #7731
    Been having AC issues and the dreaded clicking from dash. Replaced the actuator and tested. Felt a little cooler but a different noise started up and got worse. Air started coming out slower so I killed engine. Took dash apart and pulled off the blower/blower motor. Took apart and looked inside to find;
    Ac still needs a charge, I don't know if I have a leak in line or what. We'll see if it holds a charge.
  12. #7732
    Quote Originally Posted by fauskie View Post
    O.O WTF is this? Lol your galant had an abortion
  13. #7733
    02-08-2012
    Hackensack NJ
    1,146
    Wow man, I replaced my actuator since it would click with the temp change but the acuator wasn't the problem. My temp doesn't change and the old acuator was fine and the new one isn't doing anything so now idk what the problem is.
  14. #7734
    Quote Originally Posted by djaltamira View Post
    lulz!
    its not like the car was sitting for a long period of time, either. it was driven regularly.
    I think the nest was up higher in the duct and when the actuator was replaced the nest dropped down to the blower fan/motor.
    the motor was hot as shiiiit too, lucky I didnt have a cabin fire and wreck my car like Lebowski
    gave the AC a charge last night and all is working normal but I suspect I have a slow leak somewhere. hopefully its slow enough to last me thru the summer
  15. #7735
    Jdyal>>>Think they have a "shutter door or a blind door" that causes problems sometimes....someone correct me if I'm wrong
    Can you size down your sig please? Thanks, Admin :)
  16. #7736
    DISINFECT TO PROTECT! That ish is nasty!
  17. #7737
    pretty sure I increased the stock price of whoever owns Lysol
    guess I gotta put a damn trap in my car now? I have no idea where or how a mouse can get into my car, guessing thru the firewall then up the lower vents?
    fuggin disgusting!
  18. #7738
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Got a set Marc's one-way valves to stop the white smoke puffs and installed them:
    Made the adapter to a be able to log the aem wideband with evoscan:
    Relocated the gauges and the radio:
    This is how she sits, clutch is being replaced, transmission is going to be rebuilt, LSD installed and a few other things, I'll finally start my build thread when its done:
    4g64T 5spd
  19. #7739
    02-08-2012
    Hackensack NJ
    1,146
    fuggin disgusting!
    Dude I know someone with a 3g who had to take apart her whole dash and and vents because a family of mice built a nest in there and got chopped up by the blower motor.
  20. #7740
    I remember those adapters. Weren't they for the pcv valve or something??
    '95 Kawasaki ZX9R
