Thread: Post What You Did To Your Car or Bought Today!
Page 55 of 538 FirstFirst ... 54551525354555657585965105155 ... LastLast
Showing results 1,081 to 1,100 of 10744
  1. #1081
    Quote Originally Posted by Corey2kG View Post
    Thanks Matt would of been good advice before mine snapped lol. N he has his mani n tb already.
    N thanks Ally
    what did you do after it snapped. I can check u-pull for another tube since I'm going "shopping" tomorrow.
  2. #1082
    Quote Originally Posted by Rach3T8G View Post
    Fixed my EGR problem i think...
    how did u fix it?
    - If you've got nothing nice to say, what the hell is wrong with you!?!
  3. #1083
    New Member gofer03's Avatar
    09-26-2009
    Kansas City, MO
    80
    Decided its time to move on.
  4. #1084
    02-17-2011
    i live in sunny florida
    1,240
    well after taking the G to work yesterday i notice vibration in the cab put the car in nutral and its gona, did some searching thought the balance shaft might be out of time, sooo today i pull the timeing on the car in 40 min flat lined up the timing mark and its all line up the way its suppose to be, so i deside to pull the tranny mount and well guess what the mount is no good at all, gona get a new one tomarrow,
    so far i put all new motor mounts and timing belts, new acc belts, plugs, oil change, thremostat, upper and lower hoses, coa intake system, axle back exhaust, and my springs will be in next week, next will be a tranny flush with new fluids and filter, cabin filter, and ceramic pads, and rear disc break set up
    tell me what u think
  5. #1085
    04-29-2009
    Holyoke,Massachusettes
    3,600
    That would be nice Matt thanks I just put aluminum tape to block it but I have an EGR code popping up. I would appreciate it thanks.
    FreakyDeaky
    2kG 6g72/74 5 speed
  6. #1086
    ^ That wont do much. Its good you taped it off but it will still pop the code. The flange on the IM that is all opened up is the problem here. That flange leads to one of the ports of the EGR and once the EGR solenoid opens up, unmetered air goes in thru that flange into the IM and since that air is unmetered the ECU pops the code.
    How to fix it: Mount the pipe that goes into the flange, use some hose and route it to the valve cover breather hose that goes to the intake pipe. "T" the valve cover breather hose and hook up the EGR hose to it.
    Ive been running my car like that for a month now and dont have an EGR code.
    look at attachment
    Attached Images Attached Images
  7. #1087
    12-13-2010
    Brooklyn, Maryland
    4,643
    Just put an Infinity Reference 12" sub from Crutchfield into my G to replace the two blown JBL 12's, this one sounds wayyy better than the two did
    -Greg
  8. #1088
    My spark plug tube seals were leaking so I replaced the valve cover gasket and painted the valve cover while I had it off.
    And my new ralliart oil cap came in.
    Got my cold air installed as well.
    Redid my door panels last week.
    Now I am working on fiberglassing my filler panels.
    T.I. 04 BUILD YOUR OWN
  9. #1089
    I bought:
    - Windshield washer pump
    - New battery designed for low temperatures
    - New 3rd Gen tails. The old ones had some cracks and broken mounts
    - Volvo windshield sprayer (The ones that squirt washer fluid on the window, its with mist function and not 4 individual)
    - 2 new doorswithes. Those that register when a door is opened
  10. #1090
    11-29-2009
    Chadds Ford, PA
    2,768
    Twisted the VC looks good, are the door panels real carbon fiebr or a viynl??
  11. #1091
    04-29-2009
    3,600
    Quote Originally Posted by ThaShiZnitH View Post
    I bought:
    The usdm spray in kind of a mist
    FreakyDeaky
    2kG 6g72/74 5 speed
  12. #1092
    removed my valve springs, valve seals, lapped valves, put in my new springs retainers and cams and started putting her back together.
    2002
    4g64 dohc turbo 5-speed
    gt30r @20psi stock block,mbc
    2.5" tbe
    evo 8 ecu and maf
  13. #1093
    04-29-2009
    3,600
    Very nice Scott get it back on the road already lol.
    FreakyDeaky
    2kG 6g72/74 5 speed
  14. #1094
    very soon with no oil leaks, exhaust leaks, or coolant leaks.
    2002
    2.5" tbe
    evo 8 ecu and maf
  15. #1095
    installed my 74 Manifold and TB.
    I expected the Rocky Mountains to be a little rockier than this.
  16. #1096
    I bought a CD5 lip from G-spot and ordered a pass. side wheel bearing from ebay.
    Jigz-TGCIL Sosick Motorsports
  17. #1097
    02-28-2005
    Metropolis
    3,540
    bought a fog light bulb & then took two hours to install it...............
  18. #1098
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    Belts, spark plugs, and a new AC condenser.
  19. #1099
    04-29-2009
    3,600
    Tried the fix for my egr that MKO suggested n still got the CEL gonna scan it tomorrow n see if its the same code might be something else wrong. WTF!
    FreakyDeaky
    2kG 6g72/74 5 speed
  20. #1100
    received my 3 sets of hid lights, a egr window spoiler just waiting on motor mounts and me hvlp spray guns...
