Thread: Post What You Did To Your Car or Bought Today!
Page 97 of 538 FirstFirst ... 478793949596979899100101107147197 ... LastLast
Showing results 1,921 to 1,940 of 10744
  1. #1921
    08-04-2003
    NY
    4,344
    That thing looks great. I really need to get mine done. I gotta fix mine first, I tore it a little when I bottomed out in a driveway.
    99' Galant ES
    4G64/63T
    AEM EMS
  2. #1922
    04-13-2005
    Chicago
    1,945
    just got a OEM radiator for my 8G. my old one got a crack on it. have to install it tomorrow. FUN!!!!!
    n3oAcid24 = 01' Galant I4
  3. #1923
    04-29-2009
    Holyoke,Massachusettes
    3,600
    I got bored today n last night so I decided to get rid of the wood grain.
    FreakyDeaky
    2kG 6g72/74 5 speed
  4. #1924
    did you fix it?
  5. #1925
    04-29-2009
    3,600
    I got a new one today from 99galant
    FreakyDeaky
    2kG 6g72/74 5 speed
  6. #1926
    06-13-2008
    Bronx, NY
    2,606
    Good news i just tuned the 02 pcm on the g. I changed the timing and fuel maps from the eclipse gs since there maps are more agressive. And so far no check engine code and she has a better responce. The a/t is lossing most of the power. I need to go 5 speed. Next stop is to use the evo MAF since theirs has a bigger opening. Going to tune so i could tell the pcm the new settings from the evo maf.
    SOHC Turbo
  7. #1927
    New Pit Bull rear stand for the scooter, + AMSOIL FTMFW!
  8. #1928
    Jus bought my sway bar, deflectors and the rear lower tie bar ^_^
  9. #1929
    04-13-2005
    Chicago
    1,945
    installed new radiator this morning. i couldnt sleep so i decided to go ahead and get started... one question i do have is how to i get rid of all the air bubbles in the radiator now? i read a thread about it but still a little worried if i did it right.
    OLD
    Its out!
    New
  10. #1930
    06-13-2008
    Bronx, NY
    2,606
    First is first. Flush all the engine coolant out since the engine hold a lot of dirt in the coolant. Buy some radiator flush liquid on autozone or pepboys. Turn off the car and fill the radiator with water and the liquid. Let it run for 15 min on idle so it could get to operating temp. Turn on the heat on high for 10 min. Turn off the car and let it cool off. Drain all the fluid out and repeat it again. Also drain out the one on the overfill tank. After you done fill out the radiator first with coolant all the way to the top. Turn on the car; radiator cap off, fill as it will go down. When it overfills close out the cap and fill the overflow thank to where it says full. Let it cool off and double check the radiator fluid levels.
    SOHC Turbo
  11. #1931
    04-13-2005
    Chicago
    1,945
    First is first. Flush all the engine coolant out since the engine hold a lot of dirt on the coolant. Buy some radiator flush liquid on autozone or pepboys. Turn off the car and fill the radiator with water and the liquid. Let it run for 15 min on idle so it could get to operating temp. Turn on the heat on high for 10 min. Turn off the car and let it cool off. Drain all the fluid out and repeat it again. Also drain out the one on the overfill tank. After you done fill out the radiator first with coolant all the way to the top. Turn on the car; radiator cap off, fill as it will go down. When it overfills close out the cap and fill the overflow thank to where it says full. Let it cool off and double check the radiator fluid levels.
    thanks!
  12. #1932
    When you run the car with the cap off, make sure to turn on the heat inside the car. You want to make sure you are getting very hot air coming through. That means that the thermostat has opened and the coolant is flowing through the entire system.
  13. #1933
    06-13-2008
    Bronx, NY
    2,606
    Ok the big moment. I'm putting the evo MAF on the 2.4L I will use the maf scaling and other things from the evo rom and put it to my rom. TUNING TIME.. i will keep you posted
    SOHC Turbo
  14. #1934
    Put my new "daily driven" sticker on my back window today. Also reinstalled the diamond star emblem on the trunk after painting it satin black on Sunday. All this done yesterday (mon)
  15. #1935
    Sanded down my old style skirts now I just need to buy the paint.
    I expected the Rocky Mountains to be a little rockier than this.
  16. #1936
    06-13-2008
    Bronx, NY
    2,606
    Success on the 02 PCM tune. OMG This baby pull hard now "and is a A/T" LOL. Now i'm getting the full potential of my mods. Need to work more on the evo maf since the xml of the 02 galant dont have Maf smoothing and scaling. I need more adjustment on the fuel and timing since i'm jumping to bigger injector.
    SOHC Turbo
  17. #1937
    Ordered the arm rest carbon fiber...was pretty excited go get it off eBay ...got it two days ago and let me tell u very poor presentation but like described it was real carbon fiber. So if u look up close u can see waves in the clear epoxy . So I sanded it down with 180 grit sandpaper,wiped it down wit mineral spirits,
    Then whipped together my final coat of epoxy ....I work at a paint store so we have this stuff called liquid glass clear epoxy"up to 30 coats of polyurethane in one coat" POUR ON
  18. #1938
  19. #1939
    Nice...glossy
  20. #1940
    02-17-2011
    i live in sunny florida
    1,240
    picked up a fuel tank since im leaking fuel by the fuel pressure switch..... and it cant be fixed also i couldnt fill up the tank, was getting tired of smelling gas for the past 2 months
