Thread: Adjustable rear toe arms 7g and 8g
Showing results 1 to 15 of 15
    I got these off this car - it's a Dodge Intrepid ( didn't see what year it was exactly)
    It's a rear toe arm for Dodge intrepid.
    I took the short link out and then bolted the cheapest front tie rod i could find( the tie rod is for 7g not 8g)
    And Voila, adjust to the needed length, then add washers where it bolts to the subframe and you have a budget solution for the rear toe arm.
    I got two Dodge arms for $5 each and two tie rods for $17 each. That comes to $30 with the washers that i have to buy.
    Stand by for installation pictures
    Ill make a tutorial later on, but thats pretty much it. I will know exactly how many washers are necessary.
    Nice writeup!
    11-29-2009
    Chadds Ford, PA
    2,768
    great write up,
    Great writeup as usual mko
    so the dodge arms are bolt on for 8g?
    08-18-2004
    Charlotte, NC
    1,029
    mko, any results with this? I need to complete my rear suspension setup.
    1994 GS FYI
    DSM/CSM Manuals
    i have the same cuestion, any real "update" to the rear suspension whit it?
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    yeah in september
    08-18-2004
    Charlotte, NC
    1,029
    yeah in september
    got pics?
    1994 GS FYI
    DSM/CSM Manuals
    Awsome!!
    good info!!
    STAY READY AND YOU WONT HAVE TO GET READY!!
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    wow, nice find
    I'm glad to see such a terrible car has something to offer
    ^ Lol. I'm due for alignment soon, so I might be trying this.
    A couple of pics from today's project.
    So it took 2 washers and 2 locking nuts on each side. On the outside, after the toe bolts are removed, there will be round opening that needs a washer with the bolt, so it doesnt move. I have a couple of washers left, so Ill measure them and post the size later. It can be done with washers only or spacers, whatever you want to use.
    EDIT:
    Newly improved rear tow arms. No more washers to make up for the difference in sizes. These have Prothane inserts made for our cars.
    Notice the length of the tube. Compared to the first two pictures above, its much longer. This is the correct length and it matters because different Dodges have different length.
    I know for a fact that the Shadow has the correct length arms. Next time I go to the garage I'll have an exact measurement of the arm.
