Thread: Quick short shift question.
Showing results 1 to 10 of 10
    Alright, I searched and searched and searched, but I'm still not 100% sure on this. So will a 2g eclipse short throw kit fit on the 7g? Is there any modding that needs to be done to it or will it just bolt up? Thanks
    no its a bolt on deal
    yes it will fit. No modification neccessery. Takes about 10 minutes to install. I highly reccomend installing some upgraded shifter baseplate bushings. Steel are the best by far. Get the Symborski kit.
    Get the B&M replica kit. Do not get the OBX shifter.
    North Bay...NorCal
    2,552
    I might change mine...I have the short shifter for the galant....the longest shoort shifter around! LOL I Assume the eclipse one is visably shorter?
    12-17-2002
    Sherman Oaks, California
    4,304
    yes, direct bolt on. i also highly recommend the shifter plate bushings
    http://socallifestyle.com/
    1994 Galant GS 5spd
    North Bay...NorCal
    2,552
    is it much shorter than ours? I may switch mine up if it is
    08-13-2008
    Waterbury, CT
    3,331
    our stock shifter throw is rediculously long, but when u think about it being meant as a family car it makes sense.
    upgraded base bushings are a must. im either going to cut and weld mine or get a short shifter come spring
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    North Bay...NorCal
    2,552
    I dont have a stock shifter. I have a "short shifter" but its still long as fuck. I was just wondering if anyone has switched to the eclipse short shifter already and is it really short...well shorter than the one I have
    i cut the stock shifter and rewelded it so my tastes.
