Thread: timing belt scraping
Page 2 of 2 FirstFirst 12
Showing results 21 to 22 of 22
    08-04-2003
    NY
    4,344
    It looks like the balance shaft belt has no teeth on it?!?!?
    So you changed the balance shaft belt as well? If you did and you changed the oil pump, it seems as if you installed something wrong which caused the balance shaft to sieze and cause the belt to rip the teeth off. If thats the case, its all gotta get taken apart again. If it was my motor and it was out of the car, those balance shafts would be eliminated. Also you said in your PM's to me that the lifters were super noisy, is it possible that the oil pump install went bad and the whole motor didnt have oil pressure. No/low pressure will kill a balance shaft bearing quick. It could be so many different things I think the oil solution is to remove it from the car, remove the pan and oil pump to determine what is damaged.
    99' Galant ES
    4G64/63T
    AEM EMS
    04-08-2010
    Springfield, Mass
    1,225
    well ima take a look at tomorrow and take more pics
