Thread: Trip odometer, clock, and radio presets keep resetting
Showing results 1 to 11 of 11
    chadowski
    Hey all,
    I just noticed recently that my trip odometer, clock, and radio presets keep resetting sometimes whenever I turn the car on. Has anyone had this problem before? I'm guessing it's either a fuse or battery problem but I'm not sure where to begin...
    Thanks!
    EDIT: Also, I think I might have posted in the wrong forum.
    06-16-2010
    Fort Mill, SC
    2,282
    I'm having the same issue... Let me know if you find something out
    -Andrew
    10-05-2008
    Grand Rapids Michigan
    1,141
    Check your fuses, thats really all i can say
    11-13-2007
    -OKC-
    3,970
    Have you had any stereo work done??
    06-16-2010
    Fort Mill, SC
    2,282
    Yeah
    -Andrew
    11-13-2007
    -OKC-
    3,970
    Quote Originally Posted by DTP View Post
    Yeah
    The power wires on the stereo are hooked up to the wire that controls all of those things and it's not constant, that's why it resets everything, every time. Need to find a constant power wire to tap into, something that has constant power at all times. That's what happened to me, had a guy at a shop do my work because I was lazy and that happened. That's how I fixed it.
    Coolest newb eva!
    11-02-2010
    Los Angeles, CA
    137
    Hmm, the only constants I can think of are the brake lights, and the battery itself. My new radio does that, but I'm too lazy to deal with it because the radio already has issues of its own ;\.
    chadowski
    everything in my car is stock right now.. I haven't messed with any of the wiring.
    02-07-2007
    ORLANDO
    1,599
    10amp fuse in the engine bay fuse box
    chadowski
    Quote Originally Posted by 02redgalant View Post
    just switch them out? ok thanks :)
    11-13-2007
    -OKC-
    3,970
    That would not allow any power if it was blown out, not reset everything every time. When the two 10amp fuse blew out under the hood, I had no stereo at all.
