you need to rethread the two stripped threads one size bigger than the oem and use two new bolts for that thread size. you will need to remove the pan clean out the old gasket wipe the edges clean on pan and housing put new gasket and reseal pan. and be carefull not to over titghten or force in any of the bolts back in
