Thread: How to: Install 97-97 Accord Mirrors on 8G
Showing results 1 to 20 of 28
    How to: Install 94-97 Accord Mirrors on 8G
    Since everyone is trying to save money I figure modifying shouldn't be an expensive sport (all the time). These mirrors can bought on www.ebaymotors.com beteen $50-60 shipped a pair or at a junkyard for low as $20/pair compared to a full jdm set for S279.00 shipped. And that's not including paint either! I'll use The F.B.I.'s M3 tutorial as a reference. This is a basic install it will not include the power folding tut. I'll add pics for those can't picture it in their minds.
    DISCLAIMER: I am not responsible for any damage to either you or your car. This was done on a 01 Galant with a pair of OEM folding mirrors from a 94-97 Accord.
    Need:
    - pair 94-97 (CD5) Honda Accord mirrors
    - Rotary tool w/ drill
    - (6) 1 inch nut (10mm) w/ washers
    Step 1:
    - go to the G take the door panels off you’ll see the connecter witch leads to the mirror:
    Step 2:
    - Take the triangle bracket it came with and a drill, your going to drill through the part where the screws are going to go in (don’t worry the mirrors will cover them up) this will make finding the holes on the car easier.
    - paint the ends of the bolt (whatever color) so you can determine where you are gonna drill without mistakes.
    - Place your bracket on the car to where you want it to sit and use the paint markings as a guide as you drill the holes with the bracket still in hand.
    - Put your door panels back on and your done!!!
    02-28-2005
    Metropolis
    3,540
    Can we get some close up pics Pete?
    Quote Originally Posted by SkylineG1 View Post
    Excellent tutorial, I did this a few months ago after my driver side mirror was broken off. Here's my pictures:
    Hey G-Spot, does your passenger side mirror fold in more so than the driver side? For some reason I think my driver side doesn't fold in as far as the pass. side...
    maybe it's because they're aftermarket replacements..?
    Quote Originally Posted by pcriso2 View Post
    There are 3 screws that held the mirror portion and the base together try disassembling it and check for any damages? It could be the locking tab being damaged that's what happened to my old jdm mirrors.
    these look pretty good. you can see out of the glass just fine since its not from a lhd car right?
    The "Tumbler" Is Here
    3xxWHP/3xxWTQ [Current]
    11-29-2009
    Chadds Ford, PA
    2,768
    Pete, are you going to write up a wiring tut??
    04-29-2009
    Holyoke,Massachusettes
    3,600
    I was thinking of doing this but my paint is expensive :( you think all blk would be too much?
    FreakyDeaky
    2kG 6g72/74 5 speed
    The F.B.I did a wire tut for the M3 install I'd say it's very similar to this set of mirrors.
    It wouldn't be if you're going on white/black 2-toned or cf hood/trunk. But then again, those would cost more than a pint of paint
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    Is this for the Manual side mirrors or electric?
    All the mirrors checked so far were powered.
    06-16-2010
    Fort Mill, SC
    2,282
    Could I paint them myself or what?
    -Andrew
    12-18-2008
    Central Kentucky
    805
    Hey I was just wondering if you could see how close of a fit these are on the 7g? I want some new mirrors but can't afford JDM.
    Quote Originally Posted by G-spot View Post
    powered as in tilting? or power folding? lol
    Quote Originally Posted by es_fact View Post
    Power tilting. I really doubt Honda is stupid enough to put Mercedes Benz quality mirrors on their mid sized sedans lol.
    11-29-2009
    Chadds Ford, PA
    2,768
    so these do not power fold???
    Quote Originally Posted by 98mgalant View Post
    Ummm..no. Why? If you compare 7G mirrors to 8G mirrors you'd notice one has more rounded edges and the other is square shaped. You want to have something that would flow with the rest of the car otherwise it would look arkward. Next time when you head out to the Junkyards bring a measuring tape with you and search for folding mirrors that are rounded in the edges and have a close fit to the 7g. Some good examples would be an older model Sentra, some Mazdas, and 1g Diamantes.
    Of course if you look hard enough, there are JDM 7G mirrors floating around. Some 94-95 models were manufactured in Japan (hence the letter "J" on the VIN #) if you're lucky to find one these gems.
    12-18-2008
    Central Kentucky
    805
    Well I guess your right about them not flowing but the junk yards around here suck I was looking at some mirrors and they wanted $35 each for non power non folding mirrors. And finding any 7g galants at all around here is like finding a gem. I know where one is and it's about 35 miles away one way. They charged me $45 for a window motor.
Tags for this Thread
