What if you wanted to upgrade TB's? Couldn't you just eliminate the wiring?Its not driven by wire like our engines. Its electronicly controlled from the gas pedal to the throttle housing.
Thats what drive by wire means lol- electronically controlled gas pedal to throttle body.
Sent from my Blackberry Curve 3G using Tapatalk.
- Chris -2006 Mitsubishi Eclipse GS 5MT: My DD
DRL Delete | 6K HIDS | AUX Cord Wired in RF Head Unit | DC Sprots CAI | OBX Longtube Header | Aero Turbine 2540i Muffler
Now to just get a hold of the GDi 4G64....
The only thing i've found was the ECU
Tryed europeean E-Bay sites?
Yea the only things im finding is lowering springs & the ECU
Nvm i just found a complete 2.4L GDi engine
http://cgi.ebay.co.uk/MITSUBISHI-SPA...#ht_1170wt_905
You better watch what u do if ur gonna mess with Fly by wire t.b's..the motor in those are strong enough to bend the butterfly around a screwdriver. I dont think a finger would withstand that..lol
2001 Mitsubishi Galant-Totalled..=(
1987 Cheverolet IROC-Z Camaro-TPI 350
1989 Nissan 240sx-built SOHC-Trade for Honda
1999 civic Hatch B20vtec- current
Lookn for galant to build. .
IDK I think GDi just sounds "bad", but the engine actually makes less power than a DOHC 4g64. Stick with what we have here in the States guys unless you get a deal on something from everseas
I know I really want the DOHC heads off the 6g72 AWD Diamante, but hey if i dont find it SOHC will work just fine. Thats when I get an 8g one day
With 225nm at much lower revs i would say its a better engine for N/A tuning with the compression rate and all ;) And with a jap-spec ECU u get 165hp ;)
1994 GS FYI
DSM/CSM Manuals
Nope i cant find any where that says its a mivec.
http://en.wikipedia.org/wiki/MIVEC
Was looking for it on wikipedia also & I ddnt see anything about it being MIVEC
i though they had variable valve timing.
1994 GS FYI
DSM/CSM Manuals
