Thread: valve job
Showing results 1 to 6 of 6
    valve job
    so im burning oil on a regular bases and its getting annoying now
    i believe its the valve seals.... my 94 has 165,000 miles on it
    what do u guys think
    should i get a valve job or what else might help?
    and i noticed that it doesnt go as fast as it used to :/
    06-16-2010
    Fort Mill, SC
    2,282
    Just change the seals and you'll be good to go. Could be a misfire somewhere too?
    -Andrew
    Either a valve job or an engine rebuild. Oil may be leaking past the piston rings
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
    how hard would it be to change the seals myself?
    would it be good to get the head machined?
    North Bay...NorCal
    2,552
    get used to oil consumption...even after you "fix" the problem
    On my part, bought Valve Seals from Toga. Had to argue with the operator calling them Valve Covers.
    Anyways, cost me less than valve jobs here. Had to change them myself.
    should i get a Valve Cover job or what else might help?
