I4 or v6? v6 is really easy not sure about the I4. More info please.
I am needing to change my front engine mount, and wanted to find out how to do it, so I can assess if I will do it myself or take it to a shop. So, is it easy, and what tools do I need?
2002 Galant, 2.4 I4
I'm wondering which mount you are talking about. If you are looking to replace the front roll mount on the lower cross member, it is very easy. 4 bolts hold the cross member to the underside of the car, and one bolt holding the mount to the transmission. Removal takes about 5 minutes.
2017: 552whp/562wtq SBE on 19psi'02 Eclipse GT: 6G72 M/T-swapped Daily Driver'10 Endeavor: 6G75 AWD Family-mobile
It's the front one on the crossmember. Do I have to jack the car up to get to it? My main problem is I am limited on tools to do the job..
And if u jack up the engine aswell its even easyer ;)
Ok, so support engine with jack, remove crossmember, replace mount, reinstall crossmember, done? No need to place the car on stands?
no need tobut yo can for saftey. suppurt the engine....and dont put the jack stand under the oil pan
Maybe I should rephrase =)
Are all bolts accessable with the car on the ground with just the engine supported by a jack, or will the car need to be raised and then engine supported by a jack?
The reason why I'm asking on here is safety and to make sure I do it right :)
Jubeiaire, where is the best place to put the jack stand then?
Ok, now i understand better, thank you =)
Hey are those energy suspension engine mounts easy to install? I mean are they just a swap out like the OEM ones. You guys make it sound easy.
