Originally Posted by
oakrdrs187
Easiest way to do it is, leave the harness alone, and the ballast. just plug in your new H7 bulbs to your existing ballast, they should be idiot proof to only go one way. for your high beam H1, ground each bulb to the car. you might need some wire and ring terminals. get at least 14 awg wire. and then get a test light and unplug both H4 plugs turn the headlights on and put the high beams on. test the wire that has power, that is our high beam wire. Use one per side. splice your H1 power wire into it, its the one that needs a speaker type of connector and tape it. plug in the H4 to the hid relay and your done.
