Thread: LEDs in gauge cluster.
Page 1 of 5 12345 LastLast
Showing results 1 to 20 of 95
    12-19-2008
    Central Kentucky
    805
    The Galant Center nor Myself will be held responsible for the inguiry to you or damage to your car. This is for informational use only. Try at your own risk.
    1. Get yourself five 194 SMD LEDs and three 74 SMD LEDs.
    2. There are two screws at the top of the outer cover of the cluster. Remove these and gently pull that part out.
    3.Now you will see four screws around the outside of the cluster. Take them out (be careful not to drop them) grab the cluster with one hand on each side. Pull gently while wiggling it a little. Be very careful. It should pull out pretty easily.
    4.You will now have access to the back of the cluster where you will find the light sockets. The ones marked Blue are the ones that light the gauges. Remove the old bulbs and replace with SMD LEDs.
    LED light have a positive and negative so if you have one that does not work try flipping it.
    If you buy all the right size LED lights it is that simple.
    Here are a few tips.
    Do not get these.
    get these.
    I used the 194s in place of the 74s all you have to do is put the bulb in the 74 casing.
    The tape is to push the prongs out a little further and help them to get good contact to the socket.
    It also helps to tun them to the ends.
    To do this you will need to remove the tack and speedo. This will also allow you to see if they are all working. It will not fit though the hole. You will have to hold the back of the socket while pushing the bulb in. If you do not hold it firm you will break the tabs on the socket. Ignore the tin foil.
    If you do remove the speedo and tack it is a good idea to check that they work before putting everything back together. If not check the screws that hold them in if they are not in good they will not work but do not strip them out.
    when you have all your lights in and see that everything is working properly put everything back together in the opposite of removal. BE CAREFULL.
    Finished Product
    Compared to stock
    194 SMD LEDs also work great for shifter
    Parking lights
    License plate light
    Mods if this has already been done feel free to delete
    North Bay...NorCal
    2,551
    I been looking into doin something like this.....I just need to get another stock cluster. I have reverse indiglos...but this looks so much better. Why did you take the front off instead of putting them in the back? What am I missing there?
    *edit* its late...I missed the part where they dont fit! LOL, there isnt a type like those that do fit? I assume those are brighter than the ones you said dont get
    12-19-2008
    Central Kentucky
    805
    They do make smaller ones that will fit in the hole for the 74 sockets but I thought that these would be brighter so I retrofitted them. The ones that I said not to get only direct the light in one direction causing some areas to be brighter than others. Smd LEDs shine 360 degrees. I had the other kind and they are really bad.
    i like it, where i can get that led?
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    12-19-2008
    Central Kentucky
    805
    I got them on eBay the seller doesn't have any listed now but you can look at ledlights.com and search on google.
    very nice. i like it
    North Bay...NorCal
    2,551
    yeah it looks sexy. Do they make em in colors? I was thinkin blue for me....I am gonna look for the smaller ones myself....I have taken guages off before and putting em back didnt go too well! LOL my gas guage no longer works!
    12-19-2008
    Central Kentucky
    805
    ya they make them in a lot of colors. I have amber ones in my parking lights. I know they have make blue green red and amber. have you checked the screws in the back of the gas gauge. The first time when I put the crappy leds in my speedo quite working so I messed with the screws in the back and that fixed it.You should take the screws out make sure they are clean and clean around the hole on the back were they get connection. Mine were not tight enough. but they are easy to strip.
    Do the same with the HVAC controls. That panel is PITA to reach behind and get the bulbs out
    North Bay...NorCal
    2,551
    Just unscrew it and pull em out. It aint that bad
    Yo 98....these should work the same but fit into the sockets right? http://www.superbrightleds.com/cgi-b...HP5.htm#photos
    and these 74's
    http://www.superbrightleds.com/cgi-b...P3.html#photos
    That way I wouldnt have to take the guages off
    12-19-2008
    Central Kentucky
    805
    I need to get some for the hvac, ash tray, and cigarette lighter. and ya the hvac is a pain to get to. even if you unscrew it, it wont come out very far.
    Thanks for all the compliments.
    4,455
    looks great. nice and bright
    Jason - - cofounder of TGCNY
    2001 Galant ES
    12-19-2008
    Central Kentucky
    805
    Quote Originally Posted by evil-G-nius View Post
    and these 74's
    ya they should. If you get them and they dont work at first dont freak out at my trouble shooting part about tape and turning the prongs, but as far as the size ya they should fit.
    EDIT: those are a little pricey I would check eBay first.
    EDIT2: didnt find any cheeper on ebay.
    you got a link for yours? the small and big leds the go in the back of the cluster
    12-19-2008
    Central Kentucky
    805
    The seller was newcomdigi_eu on ebay but it was a promo offer so idk if they have any left.
    North Bay...NorCal
    2,551
    how many bulbs total are needed? How many 74's and 194/168's?
    12-19-2008
    Central Kentucky
    805
    I think that you will need five 194s and three 74s but don't go buying any until I double check. I'll let you know for sure later.
    North Bay...NorCal
    2,551
    Cool! Thanx
    12-19-2008
    Central Kentucky
    805
    I went and looked it's three 74 and four 194. If your going to get them for the ash tray hvac and other things you will need eight more 194s and four more 74s.
Tags for this Thread
