Thread: Current 8G Recalls... Just for info.
Showing results 1 to 20 of 39
    Galant_01
    #1 - NHTSA Recall No. 01V069
    The National Highway Traffic Safety Administration (NHTSA) has published a recall affecting certain 2001 Mitsubishi Galant, Eclipse and Eclipse Spyder automobiles manufactured in February 2001.
    On certain passenger vehicles, a bulge in the fuel tank caused by the manufacturing process resulted in thinning of the material during a welding operation, increasing the risk of fuel leakage. Fuel leakage in the presence of an ignition source could result in a fire.
    192 vehicles are affected by this recall.
    Dealers will replace the fuel tank assembly.
    The manufacturer has not yet provided an owner notification schedule.
    #2 - NHTSA Recall No. 01V295001
    The National Highway Traffic Safety Administration (NHTSA) has published a recall affecting 2001 Mitsubishi Eclipse and Galant manufactured between March 1999 - July 2000.
    Number Involved: 25,803
    Defect: On certain passenger vehicles built with V6 engines, the power steering fluid feed tube can come in contact with an exhaust manifold mounted heat shield, causing a hole to be worn through the power steering pipe and allowing fluid to leak. Leaking power steering fluid can result in a fire, and continued loss of fluid will result in a loss of power assist, increasing the risk of a crash.
    Remedy: Dealers will replace the power steering tube with one having a new routing. The manufacturer reported that owner notification was expected to begin during October 2001. Owners who do not receive the free remedy within a reasonable time should contact Mitsubishi at 1-800-222-0037.
    #3 - NHTSA Recall No. 02V147
    Mitsubishi America Has Recalled the 2002 Mitsubishi Galant because of potential electrical problems.
    Number Involved: 3,378
    Dates of Manufacture: May 2002
    Defect: On certain passenger vehicles, the routing of the vehicle’s front wiring harness can allow it to come in contact with a rough edge, allowing abrasion. This could result in grounded circuits and a loss of stop or turn signal lamp operation or engine hesitation.
    Remedy: Dealers will install a protector eliminating any harness contact. The manufacturer has reported that owner notification began July 8, 2002. Owners who do not receive the free remedy within a reasonable time should contact Mitsubishi at 1-800-222-0037.
    #4 - NHTSA Recall No. 99V305
    The National Highway Traffic Safety Administration has published the recall of certain 1999-2000 Mitsubishi Galant and 2000 Mitsubishi Eclipse automobiles, manufactured between May 1998 - October 1999, because the steering column multi-function switch levers can become loose or break over time.
    Loosening or cracking of the levers can cause directional lamps that do not self-cancel or operate, head lamps that do not turn off, windshield washers that operate continuously and/or windshield wipers that do not operate.
    Approximately 101,400 vehicles are affected by this recall. Dealers will install a redesigned switch.
    Owner notification was expected to begin during December 1999. Owners who do not receive the free remedy within a reasonable time should contact Mitsubishi at 1-800-222-0037.
    #5 - NHTSA Recall No. 99V333
    The National Highway Traffic Safety Administration has published the recall of certain 1999-2000 Mitsubishi Galant and 2000 Mitsubishi Eclipse automobiles, manufactured between May 1998 - November 1999, because, on certain vehicles equipped with V6 engines and Federal emission equipment, the battery cable wiring harness can become heat damaged by the front exhaust manifold which could cause grounded circuits.
    This circuit failure could cause any of the following to occur:
    (1) the engine will not start because the main fuse will blow if the power lead is grounded.
    (2) the low oil pressure warning lamp will illuminate if the signal wire is grounded.
    (3) the air-conditioning system will become inoperative if the lead to the magnetic clutch is grounded.
    (4) the turn signal/hazard lamps will become inoperative if the voltage monitor lead is grounded.
    Approximately 20,000 vehicles are affected by this recall. Dealers will remove and discard a metal manifold bracket (from Galant models only - Eclipse has no such bracket).
    Dealers will also inspect the harness. If the harness wires show no damage, the dealer will install a heat insulator along with heat resistant harness clips. If the harness wires do show damage, the dealers will install a new harness with pre-installed integral heat protection.
    Owner notification is expected to begin during January 2000. Owners who do not receive the free remedy within a reasonable time should contact Mitsubishi at 1-800-222-0037.
    These are all the current recalls for the 1999-2003 Mitsubishi Galant.
    Just thought I would put these here just in case anyone ever wanted to know without doing the research.
    I got a 99 V6 and my right turn signal just started to skip a tick you know that sound it makes when you turn tick tock well mine sometimes ticks but no tock and then its fine again?? wierd :?
    SportBike Powder Coating
    "Not Just Bikes"
    [email protected]
    Photos
    http://www.photobucket.com/sportbikepowdrcoating
    Black Magic
    will the dealerships notify use cause i bought the car brand new from the mitsu dealership, or will we have to go down there and ask for a check up on these things?
    clone2020
    Go here -> http://www-odi.nhtsa.dot.gov/
    -Mike.
    recall
    call the 1-800-222-0037 and keep hitting 0 to talk to a real person. Give them the last 8 digits of the VIN # and they will tell you about any recalls for the car, and if they have been fixed (if you bought the car used)
    ChikagoGTZ
    :doubleup: Honda
    <img>
    Brand New Used Galant....
    <span style='color:red'>Hey, just a quick question. Would the dealership notify you of recalls if you bought the vehicle from them but it wasn't their brand?? In my case, I bought my '00 Galant at the Ford dealership but the Mitsubishi dealership was in the same area, just up the hill??? </span>
    edidas's <span style='color:red'>~GuamGrooves~</span> galant
    03-01-2005
    Houston, Tx
    1,049
    recalls
    naw dude your gonna have to call the 1800 number and give them ur vin number. Then they will put your name in the system and contact you on any new recalls.
    thanks....
    aahh, ic.. thanks.
    08-23-2004
    Chaska, Minnesota
    1,370
    damn im glad i got an '03. its best not to get a new modle car, should hait a few years so the kinks can be worked out.
    (i.e.) the honda civic hybrid. gas/electric car, awesome idea except its always in the shop for recalls/repairs. if you plan on getting one i suggest you wait a few years till they get all the "kinks" worked out. my $.02
    Good info. Only posting in order to have this in my post page so i can find it if needed.
    02-28-2005
    Metropolis
    3,540
    Just called and they added me as teh owner but good news, my car is cool.
    08-23-2004
    Chaska, Minnesota
    1,370
    should add intake manifold :evil:
    i agree,
    my intake manifold cracked caus the bolting nuts are too long,
    i saw some other peeps having the same problems
    2002 blue G RIP07
    2003 grey G with the heart of an Evo 8
    1999 beige G . winter beater and well its beige
    Experienced TGC Member glantv699's Avatar
    04-14-2005
    PA
    1,046
    Glad this thread popped up....
    My signal doesn't always shut off when i turn left and lately my HIGH BEAMS have been going on while the car is parked. The guys I work with always come in and tell me, your lights are on again!
    I thought it was just the Galant getting old....but a recall- they should still fix it now right?
    > TGCPA - SOUTHEAST
    > 1999 ES V6 (Sold 2/2011)
    crisby_GTZ
    also, anyone have a problem with their front dash speaker? i know 3 at my collge, including me, with 02 galants where the dash speaker was busted...just wondering if anyone else here had that problem? i figure it's gonna be a fortune to replace so i just disconnected it..
    <div class='quotetop'>QUOTE(krispy03)</div><div class='quotemain'>should add intake manifold Â*:evil:</div> :laughing:
    Baltimore, MD
    2,848
    <div class='quotetop'>QUOTE(crisby_GTZ)</div><div class='quotemain'>also, anyone have a problem with their front dash speaker? i know 3 at my collge, including me, with 02 galants where the dash speaker was busted...just wondering if anyone else here had that problem? i figure it's gonna be a fortune to replace so i just disconnected it..</div>
    The stock center speaker is crap. Mine blew as well, but I went to Best Buy and found a pair of Rockford Fosgate Punch P132C speakers for $50. It's a 3.5" two-way speaker that kicks ass! Only minor modification needed to make it fit and cover it with the stock speaker grill too. Plus I have a spare.
    Chip
    (Paint Code: Porsche LC9Z)
    Quote Originally Posted by Fishboy55
    The stock center speaker is crap. Mine blew as well, but I went to Best Buy and found a pair of Rockford Fosgate Punch P132C speakers for &#036;50. It's a 3.5" two-way speaker that kicks ass! Only minor modification needed to make it fit and cover it with the stock speaker grill too. Plus I have a spare. :D
    So what modifications would need to be done. Because mine went out a while ago.
    I'm curious about the speaker as well. Mine pops now when the volume is up too high. Thinking it'll be toast soon.
    })({ Heather })({
    - "If you never take risks, you'll have a wasted soul."
    My headlights occasionally cut off by themselves, especially when changing from hi/lo beams. And I see #4 may affect my car. Can I still call a dealership to fix it?
    I just called the 1-800 number, it seems that the switch was fixed in 99....damn.
