Thread: 7g but with 4g63 sohc
Showing results 1 to 20 of 37
    Ironzep
    Hey guys,
    Im new to this forum and I've got a 7g Galant Gsr (New Zealand new)
    It runs the 4g63 sohc which is lacking in the power department so im looking for some simple cheap mods to improve the power, for now i want to keep it NA.
    I know this probably isn't the right place to look because all you guys have is the 2.4L model.
    But if you could either point me in the right direction in this forum or give me some ideas for some simple cheap mods it would be much appreciated.
    Cheers
    North Bay...NorCal
    2,552
    well it doesnt really matter where you look (here) none of us have ever seen that motor. We only got the 2.4 and the only variation was SOHC (the norm) or DOHC (1 year production) doubt we can be much help! But as far as styling and other things....your in the right place! LOL Welcome
    11-18-2009
    Buffalo, NY
    1,758
    WelCome 2 TGC!!
    Sent from Blackberry using Tapatalk
    - Chris -
    DRL Delete
    welcome men:D, have pics? :p
    __________________
    -Mitsubishi Galant (4G64 SOHC) ES 1996, 5spd Swapped.
    -Mitsubishi Galant LS 1994 a/t [ SOLD ]
    If its fuel injected then it has a distributor. If its this kind of engine then everything youll find in this forum applies for your engine. Im sure they even look identical. Bigger Throttle body, Exhaust, Headers, CAI, turbo, even DOHC swap will be the same for you .
    It all depends on what youre looking to do it and how much of a commitment you have
    If it has carburetor, then IDK how much of a help we will be. The options then are very limmited
    Ironzep
    Its definately fuel injected, So are you saying that even though my engine uses the 2.0 block, alot of the stuff is going to be the same? or just similar?
    I assume the easiest thing to do would be a CAI, so that going to be first on the list.
    04-29-2009
    Holyoke,Massachusettes
    3,600
    Welcome to TGC! We got some sick 7g's here just look around.
    FreakyDeaky
    2kG 6g72/74 5 speed
    Welcome.
    North Bay...NorCal
    2,552
    Is it 5 speed? If not, do a trans swap and that will make better use of the power that is there. Out of curiosity....what is the hp rating on that engine stock?
    Ironzep
    Thanks for the welcomes guys! Its 5 speed which is a big bonus. I just looked it up and apparently its 137hp or 101kw. the engine bay layout is exactly the same as your guys 2.4 so I'm gonna get one of those kits of ebay and install that first.
    The ebay kits are expensive. Just get a couple of couplers, some exhaust piping, the MAS adapter and a filter. 2.5'' pipes will do it
    North Bay...NorCal
    2,552
    got pics of the car? engine bay too
    Ironzep
    I'll try and get some pics tomorrow.
    One of those ebay kits for an eclipse is only 70 USD with shipping to NZ, with the NZD being quite strong and USD weak right now its probably the cheapest easyist option.
    02-18-2009
    NEWBURGH, NEW YORK
    486
    my 6gen had a 4g63 sohc 8 vavle in it
    Im sure he has the 16V SOHC
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    Welcome to TGC!
    Probably your cheapest route to real power gains would be a used 4G63-T swap out of an Evo 1-3 with an appropriate ECU. I know you said you want to stay non-turbo but that will still be your best bet in the long run. You can try adding little HP gains here and there on the N/A motor but you'll spend more and get less.
    If you're eager to start modifying then suspension work is a good first step. You'll have a lot more fun putting what power you do have down to the ground. After that save up for the turbo conversion (or a used Evo... wish we had those earlier gens here!)
    welcome
    Nobody built like u, u desighn ur self.
    5spd swap
    full custom body conversion
    18x9 Works VS
    Big 16g evo3T next project
    02-18-2009
    NEWBURGH, NEW YORK
    486
    true. I have heard of that motor. That was never released in the usdm market ?
    NAh, the closest would be the 4g94 2.0L 16V SOHC found in 02-07 Lancers
    Ironzep
    At some point i definatly do want to do a 4g63t swap, but right now i dont really have the time or money. Suspension might actually be second on the list with the added bonus of some aesthetic gains as well. Is it true that if i upgrade to an 1g throttle body that to get full potential from it i'll need to uprade the exhaust/headers as well?
