Thread: Turbo Flow rates and IC piping
Showing results 1 to 17 of 17
    I did some research and found some useful info on turbo flow rates and when the IC pipes start to restrict and when the pipes are an overkill that creates turbo lag.
    *.4 Mach is the point at which air becomes turbulent and losses in efficiency start to occur exponentially. The key is to stay under that speed. You want to use the smallest piping possible that still flows enough to meet your needs. Larger than necessary piping increases lag time with no measurable gain
    The velocities are in miles per hour and mach, and the flow rates are in cfm. Measurements for the piping are in inches.
    2" piping
    300 cfm = 156 mph = 0.20 mach
    400 cfm = 208 mph = 0.27 mach
    500 cfm = 261 mph = 0.34 mach
    585 cfm max = 304 mph = 0.40 mach
    2.25" piping
    300 cfm = 123 mph = 0.16 mach
    400 cfm = 164 mph = 0.21 mach
    500 cfm = 205 mph = 0.26 mach
    600 cfm = 247 mph = 0.32 mach
    700 cfm = 288 mph = 0.37 mach
    740 cfm max = 304 mph = 0.40 mach
    2.5" piping
    300 cfm = 100 mph = 0.13 mach
    400 cfm = 133 mph = 0.17 mach
    500 cfm = 166 mph = 0.21 mach
    600 cfm = 200 mph = 0.26 mach
    700 cfm = 233 mph = 0.30 mach
    800 cfm = 266 mph = 0.34 mach
    900 cfm = 300 mph = 0.39 mach
    913 cfm max = 304 mph = 0.40 mach
    2.75" piping
    300 cfm = 82 mph = 0.10 mach
    400 cfm = 110 mph = 0.14 mach
    500 cfm = 137 mph = 0.17 mach
    600 cfm = 165 mph = 0.21 mach
    700 cfm = 192 mph = 0.25 mach
    800 cfm = 220 mph = 0.28 mach
    900 cfm = 248 mph = 0.32 mach
    1000 cfm = 275 mph = 0.36 mach
    1100 cfm max = 303 mph = 0.40 mach
    3.0" piping
    300 cfm = 69 mph = 0.09 mach
    400 cfm = 92 mph = 0.12 mach
    500 cfm = 115 mph = 0.15 mach
    600 cfm = 138 mph = 0.18 mach
    700 cfm = 162 mph = 0.21 mach
    800 cfm = 185 mph = 0.24 mach
    900 cfm = 208 mph = 0.27 mach
    1000 cfm = 231 mph = 0.30 mach
    1100 cfm = 254 cfm = 0.33 mach
    1200 cfm = 277 mph = 0.36 mach
    1300 cfm max= 301 mph = 0.39 mach
    And the flow rates of most Mitsu turbos
    Flow Rates @ 15psi:
    TDO4-9B-6CM2 265 CFM
    TDO5-12A-8CM2 320 CFM
    TDO4-13G-5CM2 360 CFM
    TEO4-13C-6CM2 360 CFM
    TDO4L-13G-6CM2 360 CFM
    TDO4L-15C-8.5CM2 390 CFM
    TDO5H-14B-6CM2 405 CFM
    TDO5H-14G-8CM2 465 CFM
    TDO5H-16G-7CM2 505 CFM
    TDO5H-16G-10CM2 505 CFM
    TDO6-17C-8CM2 550 CFM
    TDO6H-20G-14CM2 650 CFM
    TDO7S-25G-17CM2 850 CFM
    TFO8L-30V-18CM2 1200 CFM
    If you have the pounds per min rate or lb/min of a turbo the conversion is done easily:
    lb/min x 14.27 = CFM
    Example: Big16g has max flow rate of ~39-40 lb/min
    40lb/min x 14.27 = 570 CMF
    Which means that even 2'' pipes do not restrict the MAXIMUM flow made by Evo3-8 B16g.
    Now imagine the lag you get from 2.25 or 2.5'' pipes on 14b!
    These conclusions are based on low level boost 8-15 psi on stock internals motor.
    Credits go to gstryyder on DSM Tuners and boomtown on EvoM.net
    Some more info on air losses
    2.25" O.D. straight tubing: 0.17 psi per foot
    2.5" O.D. straight tubing: 0.10 psi per foot
    3" O.D. straight tubing: .04 psi per foot
    2.25" O.D. 90* bend: 0.27 psi per bend
    2.5" O.D. 90* bend: 0.17 psi per bend
    3" O.D. 90* bend: .08 psi per bend
    So having the shortest route from the turbo to the throttle body will equal more psi at the intake manifold
    the way i understand these numbers is that the bigger the diameter is the less air you lose, am i seeing things or is there a mistype in here ??
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    08-04-2003
    NY
    4,344
    That info is a good guide, real world results though wouldnt fit that guide as written though. Larger diameter pipes cause a "pressure drop" due to the turbo having to work harder to fill the larger pipes thus creating more lag. The info about losing air pressure around bends based on diameter doesnt make sense though, that info is based on an engine thats 100% efficient. If the engine used all the air at the same rate the turbo is pushing it out then you would never be able to create boost pressure. The same given amount of air will have more pressure if forced into a smaller diameter pipe versus a larger diameter pipe when keeping all other variables constant. God I hate math......
    99' Galant ES
    4G64/63T
    AEM EMS
    ok so here is my question.
    my intercooler is 2.5". i got a big 16G i'm going to be using. i got a FP j pipe that goes from stock size to 2"
    million dollar question is what size charge pipes to run??????
    11-29-2009
    Chadds Ford, PA
    2,768
    2.25, or 2.5 would be my guess from reading the chart
    08-04-2003
    NY
    4,344
    Nope, the chart would say a 2" charge pipe would still allow more flow than the turbo could produce, so 2" is fine, you can go to 2.5" if you would like, but you dont need to and running the larger pipe can cause a bit more lag, but lag is non-existant on a 2.4 engine and a 16g anyway, so your fine either way. If you run 2" pipe from the turbo to the intercooler, you should run a 2.5" pipe from the intercooler to the throttle body. Since the intercooler is 2.5" in/out, you would be causing a bottle neck by reducing the outlet from 2.5 to 2.0, it would still work fine, but rule of thumb is to not create a bottle neck.
    99' Galant ES
    4G64/63T
    AEM EMS
    Hey thats why I went from full 2.5'' after the j-pipe to the TB to 2'' from j-pipe to IC then a "bottle neck" from 2.5'' to 2'' so it can go thru the radiator subframe and then to 2.5'' for the UICP all the way to the TB (since my TB is 60mm = 2.5'')
    Big difference in how the turbo spools, car kicks much harder now, BOV is 100% louder
    08-15-2006
    Perth Amboy, NJ
    1,558
    2.5" piping
    I'm a lil confused (maybe i'm reading it the wrong way).
    For a 14B at 15psi, you're seeing about 405 CFM.
    With a 2.5" setup that's only 0.17 Mach.
    Maybe with that low of boosted pressure lag would be more probable?
    I was planning on doing 2.5" piping all around with the 14B; maybe i should do 2" instead and open up to 2.5 at my TB?
    run1206's Rear Disc Tutorial
    2.5 is way too big for 14b, its even big for a maxed out 16g
    i'm going to do the 2 inch to the intercooler and 2.5 after. thanks for the info
    08-13-2008
    Waterbury, CT
    3,331
    drew are you leaving the stock 6cm hot side on the 14b? i recommend getting the 7cm housing for it from a 16g, find a blown 16g big or small, but it, swap the compessor wheels and covers and hot side and youll be all set.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    you cant just swap the compressor housing and wheel. There is this bed in the center housing where the wheel sits in and that is different for every MHI turbo. As the turbo size goes up the wheel size and that bed size go larger as well.
    08-15-2006
    Perth Amboy, NJ
    1,558
    i thought somebody else did the same mod as well... :?
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by run1206 View Post
    i have a 14b chra with a 16g wheel and compressor cover sitting in my basement that i rebuilt and it spins just fine, only difference is the 14b is flat back wheel and the 16g is a superback wheel
    2014 Lancer Evo GSR
    So any of these 2.5" intercooler and piping kits off ebay will handle the 25G turbo just fine?
    yes it will.
