Thread: Headlight switch?
Showing results 1 to 19 of 19
    12-18-2008
    Central Kentucky
    805
    Headlight switch?
    I was driving down the road when without warning my headlights whent out. When they did the battery and break light came on. I looked at it for about 5min and decided to try the brights. They worked so I drove home with them. Although they did look dim I'm thinking that was because the lowbeams were not on.
    1 is there a fuse for low beam headlights?
    2 what are the chances that this is the switch?
    Use a multi meter to check all your fuses start the car and check each one, walmart has a multi meter for like 12 buck that beeps when there is connection all you do it put the two prongs on the top of the fuse where the metal sticks up a bit and see if it beeps this way you don't have to pull each one. Takes about five to ten mins to complete
    Sent from my SPH-D700 using Tapatalk
    1996 galant s
    06-16-2010
    Fort Mill, SC
    2,282
    Harbor freight has 'em cheaper and i can point you to a coupon for a free one
    -Andrew
    06-16-2010
    Fort Mill, SC
    2,282
    Alternator?
    -Andrew
    12-18-2008
    Central Kentucky
    805
    I just replaced the altinator so I hope that's not what it is.lol. Knowing my luck that's what it is.
    Use a voltage tester right on the battery posts. With car idling it should be charging at over 13.5 volts even with all the accessories and lights on.
    06-16-2010
    Fort Mill, SC
    2,282
    Quote Originally Posted by w/oarctic7g View Post
    Did you lose power to anything else?
    That'll tell you right there.
    -Andrew
    09-25-2006
    Central, Cali
    1,145
    Sounds like a alty problem but i would check fuse first
    03 I4
    North Bay...NorCal
    2,552
    sounds like a fuse problem to me. But in the same respect, I think the headlight fuse works for both high and low beams. The headlight fuse is a 15 amp....definately start there and then move to the "harder" stuff. Even if the alternator goes bad it wouldnt make the lights cut out while the car was running I dont think.
    12-18-2008
    Central Kentucky
    805
    Well I think that if it was the alternator it would have done other things too. The radio still worked, heater blower, interior light. Under the hood there is a fuse labled high beams but I could not find one for low. I drove aboul 30mls like this stoped and go for about 5 and full speed the rest of the way. Idk what it is but I'm going to look around today. Thanks and keep them coming.
    Not the Alternator. If it was the alternator you'd had lost everything and eventually the car would just stop running. I broke an alternater belt and tried to drive to the parts house to get a replacement. I only got 15 miles down the road before the car just shut down from draining the battery without it being re-charged b y the alternator.
    Here's an off the wall suggestion. If you had one low beam head light already burnt out and the other just died it would appear as if you just suddenly lost your low beam headlights. Many folks drive around not realizing they have a head light out. Try switching out one of the low beam bulbs.
    jjj
    12-18-2008
    Central Kentucky
    805
    They were both burnt out. I don't know it the other one went yesterday day too or not but I know that they both worked a few days ago. I hope that it's just because they blew.
    North Bay...NorCal
    2,552
    but if you got dash lights at the same time....its gotta be a fuse. Simply saying that cus we dont have monitors for that. So I still say its the fuse....you rocking HIDs? They rarely go out and never both at the same time, so again I think its a fuse issue. its in the fuse box under the hood (just in case you didnt know, which I am sure you did) 15 amp
    98Galant,
    Clarify what you have on your car; OEM stock headlights and bubs or HIDs
    --If OEM headlights try replacing one bulb and see if it works.
    --If HIDs, check the wiring by the lights for an "extra" in line fuse or a broken connection and as evil-G-nius wrote, check the fuse box under the hood.
    jjj
    12-18-2008
    Central Kentucky
    805
    It is my new alternator. The voltage regular went out and blew the bulbs and now my car won't start or anything. Going to exchange it Tuesday. Thanks guys. Also I have oem headlights. I remembered that I had just checked to see if they were even siting at the store before I took off.
    u should of tested the alternator at the store when u bought it
    12-18-2008
    Central Kentucky
    805
    Quote Originally Posted by spencer0791 View Post
    Well its a little late for that isnt it.lol jk
    I had a new alternator go bad after about 2 months. was awefule because the voltage regulator got stuck and it caused my battery to be overcharged. of course the battery boiled over spitting acid all over my engine bay. Chemical burns everywhere. Sucked.
    North Bay...NorCal
    2,552
    My alternator (always) is weak. I mean when I first turn on the car it runs at between 10 and maybe 12 volts. When I rev the car to 2500 or so it hits 13-14 volts where it should be. It has ALWAYS done this and I have no idea why. ANyone?
