Thread: DTP's 8G Build
Page 13 of 30 FirstFirst ... 39101112131415161723 ... LastLast
Showing results 241 to 260 of 592
  1. #241
    06-16-2010
    Fort Mill, SC
    2,282
    Pushin' Leaves
    (yes Matt, moar low is needed!! LMAO!)
    -Andrew
  2. #242
    12-13-2010
    Brooklyn, Maryland
    4,643
    Love the footwell lighting, I need to do the same to mine. Looking good Drew!
    -Greg
  3. #243
    05-05-2011
    Medford/Long Island, NY
    2,135
    Hope those Bullitt wheels aren't seeing snow...
    -Chris-
  4. #244
    06-16-2010
    Fort Mill, SC
    2,282
    Thanks Greg! And Vic!
    It's real simple and easy to do. I tapped the radio power in, and ran my switch from that. That way, if i leave them on, they shut off with the car.
    -Andrew
  5. #245
    02-17-2011
    i live in sunny florida
    1,240
    Light bulb..
    Looks great what did u use for the foot wells, I was thinking of useing cold cathoids I have laying around from ky computer build I did not too long ago
    HTC EVO 4G
    MODS
    5 speed swap
    Eibach Pro Kit on GR2 Struts
    Cold Air Intake
    Outlander Intake Manifold
    6G72 V6 Throttle Body
    6G72 V6 Fuel Pump
    Axle Back Exhaust (ebay)
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
    Prothane Motor Mount Inserts
  6. #246
    06-16-2010
    Fort Mill, SC
    2,282
    Quote Originally Posted by Skyforger View Post
    Here in SC we won't see snow for awhile... And only for a couple days at that. Not much to worry about there, Chris. And i still have my Eclipse GT wheels at my dad's shop!
    -Andrew
  7. #247
    06-16-2010
    Fort Mill, SC
    2,282
    Quote Originally Posted by finald8ta View Post
    Light bulb..
    HTC EVO 4G
    I used some LED strips i bought off of eBay last year.
    -Andrew
  8. #248
    02-17-2011
    1,240
    Sweet I have a set of those in my cluster and in my xbox360
    HTC EVO 4G
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  9. #249
    06-16-2010
    Fort Mill, SC
    2,282
    Cluster!?
    -Andrew
  10. #250
    02-17-2011
    1,240
    Guage cluster in th G to help eliminate hot spots from the led I have alrdy installed
    HTC EVO 4G
    MODS
    5 speed swap
    Cold Air Intake
    6G72 V6 Fuel Pump
    Evo Fuel Rail
    Evo Radiator
    Rear Disc Swap
  11. #251
    06-16-2010
    Fort Mill, SC
    2,282
    Oh okay... Makes sense
    -Andrew
  12. #252
    You can ditch the switch and power them direct to the memory wire and ground them to the door trigger wire, they will come on with doors.
  13. #253
    06-16-2010
    Fort Mill, SC
    2,282
    I was looking at wiring them to the O/D switch like we talked about.
    I haven't looked at my shifter specifically, but if i'm reading this wiring diagram out of the Hayne's manual, i should tap into the RED/YEL wire coming from the switch to the O/D indicator?
    -Andrew
  14. #254
    Not sure what you mean, but basically use the switch on the shifter instead of the switch you put on the dash. 2 of the wires will be internally connected when you press the switch and disconnect when you press again.
  15. #255
    06-16-2010
    Fort Mill, SC
    2,282
    I haz these:
    How do i wire them in with my stock harness?
    https://www.thegalantcenter.org/showthread.php?t=17294
    ^ no help :(
    -Andrew
  16. #256
  17. #257
    03-12-2007
    Dallas TEXAS
    2,041
    aw yeaaaa
  18. #258
    12-13-2010
    Brooklyn, Maryland
    4,643
    That's the link i used to get me going, just match up the colors and you're straight!
    -Greg
  19. #259
    05-05-2011
    2,135
    Pre-facelift tails! Silver and these tails just work so well. Just sayin'. ;)
    -Chris-
  20. #260
    04-29-2009
    Holyoke,Massachusettes
    3,600
    Thats the link I texted you biotch!!!! lol
    FreakyDeaky
    2kG 6g72/74 5 speed
