Thread: mysticj's 2011 Build
Page 10 of 14 FirstFirst ... 67891011121314 LastLast
Showing results 181 to 200 of 262
  1. #181
    06-16-2010
    Fort Mill, SC
    2,282
    This is awesome, I need to see in person
    Sent from my SGH-I777 using Tapatalk 4 Beta
    -Andrew
  2. #182
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by DTP View Post
    +1
    I need to sort some things out first though
    1994 GS FYI
    DSM/CSM Manuals
  3. #183
    08-18-2004
    Charlotte, NC
    1,029
    Working on a few items
    1994 GS FYI
    DSM/CSM Manuals
  4. #184
    08-18-2004
    Charlotte, NC
    1,029
    Hopefully to do the Equal Length Axle and Dual Piston Calipers Mods by the end of the month. Switch to a #501 MAS from the #011 as the #011 flow a tad more than the ECU would handle w/o a SAFC to compensate(Hard starting at times, almost stalling on deceleration). I kept the #011 honeycomb mesh and snatch a #482 airhorn for a hybrid MAS setup once I get a SAFC & WBO2. Also, leaning towards a MAFT Pro for the ITBs
    1994 GS FYI
    DSM/CSM Manuals
  5. #185
    BE careful with the bolts on that camber kit. Really easy to snap. Make sure you use enough grease on them bolts too.
  6. #186
    08-18-2004
    Charlotte, NC
    1,029
    Thanks for the heads up!
    1994 GS FYI
    DSM/CSM Manuals
  7. #187
    08-18-2004
    Charlotte, NC
    1,029
    1994 GS FYI
    DSM/CSM Manuals
  8. #188
    Did you do it cuz of wheel hop?
    And do you mind sharing the COP wiring diagram w/o power transistor?
  9. #189
    08-18-2004
    Charlotte, NC
    1,029
    Yup. Let me dig up the wiring diagram for it.
    1994 GS FYI
    DSM/CSM Manuals
  10. #190
    08-18-2004
    Charlotte, NC
    1,029
    Running out of things to remove to lower the weight without going too extreme, i.e. no carpets.
    For the front: slim radiator fans, remove PS bracket; adding the dual piston calipers and larger rotors will bring the weight back up.
    For the middle/cabin: remove sound deafening, sunroof.
    For the rear: Nothing left to remove.
    1994 GS FYI
    DSM/CSM Manuals
  11. #191
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    smaller battery?
    Just because something is old, doesn't mean you throw it away
    Geordi La Forge
  12. #192
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by foxbrand View Post
    smaller battery?
    Im quite pleased with the U1 battery. Even starts the car on sub freezing conditions(7 degrees)
    1994 GS FYI
    DSM/CSM Manuals
  13. #193
    08-18-2004
    Charlotte, NC
    1,029
    Some engine bay dress up...Volvo S40 brake reservoir cap and Diamante Vacuum Reservoir for the Cyclone IM
    Honda OE battery tie down
    1994 GS FYI
    DSM/CSM Manuals
  14. #194
    that battery tie down looks nice! Specifically what honda did you get it from? I might grab that unless I can find something else.
    1994 Galant GS - Daily driver
    1994 Galant LS - Parts car
    Garage: http://www.thegalantcenter.org/garag...iew-20241.html
  15. #195
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by DEADEYES View Post
    I think its from a 04+ Accord.
    1994 GS FYI
    DSM/CSM Manuals
  16. #196
    thx i'll have to keep my eye out for one.
  17. #197
    08-18-2004
    Charlotte, NC
    1,029
    Finally install some Volvo S40 280mm front rotors with the 1G Diamante dual piston calipers. Had to grind the upper and lower section of the calipers to fit the rotors. Also make some hardlines with the new brake hoses I find off a Mighty Max. Works great!
    Also install a new radiator from a 97 Galant that was in the yard. Running about 15* cooler now.
    1994 GS FYI
    DSM/CSM Manuals
  18. #198
    12-13-2010
    Brooklyn, Maryland
    4,643
    So S40 parts fit 7G's? I was talking to Pernir and he wanted to use the S40 manual trans, and I found out that Mitsu supplied Volvo with the platform for the 1G S40. My thought was that the S40 would be more compatible with the 8G though. Still, good news if other parts will fit at least one gen of Galants!
    -Greg
  19. #199
    08-18-2004
    Charlotte, NC
    1,029
    The 1G S40 is based off the Mitsubishi Charisma, which is basically a mid size Lancer.
    1994 GS FYI
    DSM/CSM Manuals
  20. #200
    Ha nice. I heard that S40 1.9T is based on Evo 4g63 engine , but with less displacement.
