Thread: mysticj's 2011 Build
Page 11 of 14 FirstFirst ... 7891011121314 LastLast
Showing results 201 to 220 of 262
  1. #201
    08-18-2004
    Charlotte, NC
    1,029
    Ordered a new 2G GSX LH axle, the current one is causing vibration.
    1994 GS FYI
    DSM/CSM Manuals
  2. #202
    08-18-2004
    Charlotte, NC
    1,029
    Well, had some misfire lately and the last couple of weeks it was getting worse. I notice some leakage at the intake manifold/head area. So I decide to change the gasket, as I was pulling the manifold off I heard some thing fell. To my surprise it was a piece of the manifold. Don't know how, other than possible fatigue or vibration. All other runners at the flange have a semi circle crack. There goes the era of my snapping throttle response.
    Pick up a 1G intake manifold and 3KGT TB. Back to a more stock look.
    One of my coilpacks took a crap the day I remove the Cyclone intake manifold. Throw in a set I had laying around in the garage.
    1994 GS FYI
    DSM/CSM Manuals
  3. #203
    Ouch that sucks, is there a noticeable difference without the cyclone?
    1994 Galant GS - Daily driver
    1994 Galant LS - Parts car
    Garage: http://www.thegalantcenter.org/garag...iew-20241.html
  4. #204
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by DEADEYES View Post
    Yes, with the Cyclone and 65mm TB the engine was more response and when the butterflies open at 4300rpm, the rpm climbs hard. With the 1G IM and 60mm TB, is a smoother climb in power, subtle yet noticeable.
    In other words, I loss some low to midrange torque.
    1994 GS FYI
    DSM/CSM Manuals
  5. #205
    08-18-2004
    Charlotte, NC
    1,029
    rear brace
    1994 GS FYI
    DSM/CSM Manuals
  6. #206
    I have that manifold in pieces somewhere. If i find it you can have the bottom portion of it.
    And that usually happens from not having the bracket from IM to block
  7. #207
    08-18-2004
    Charlotte, NC
    1,029
    I figure that out but I sold the manifold.
    1994 GS FYI
    DSM/CSM Manuals
  8. #208
    08-18-2004
    Charlotte, NC
    1,029
    Remove some more items in the rear.
    Remove majority of the airbag/SRS system
    1994 GS FYI
    DSM/CSM Manuals
  9. #209
    Might as well pull those rear seatbelts as well. the reels probably weigh a couple of lbs each. My favorite part of two stage intake manifolds is the engine note change when the butterflies open.
    What ever happened to your ITB setup plans?
  10. #210
    08-18-2004
    Charlotte, NC
    1,029
    I could but it will take more time to put them back in if I want to drive the kids around town. LOL
    The ITB, they are more or less still on the table. Converting to an Evo/Lancer ECU and reflash with a SD ROM is an option, as well as using a MAFT PRO.
    They[ITB] will definitely max out my current setup but the driveabitily will definitely decrease. The price for Borla/TWM air box went up and having one ship from oversea [UK] is not even worth it. There is a guy in PR running a 4G64 SOHC in a Mirage making 232whp and since then, I'm slowing collecting parts for a SOHC project.
    1994 GS FYI
    DSM/CSM Manuals
  11. #211
    Make me a brace like this. I needs it
  12. #212
    08-18-2004
    Charlotte, NC
    1,029
    The one I made is a prototype and if I make another one, it's going to be lighter but still durable. DTP says he might want one. I post my brace on DSMTuners and GreenGoblin approves of it, and that says a lot coming from a guy who's car is badass time attack machine.
    But for which car? I don't think its going clear with an exhaust that goes under the rear crossmember.
    1994 GS FYI
    DSM/CSM Manuals
  13. #213
    Depending on the final product I would like one as well ;]
  14. #214
    TGC Lifetime Patron Solviss's Avatar
    12-04-2013
    Jacksonville, Florida
    260
    Same lol
  15. #215
    I has many Galants, dont worry
  16. #216
    08-18-2004
    Charlotte, NC
    1,029
    Ok. I'll see if DTP(Drew) still wants one. It should fit his 8G but if it doesn't I can rework the two brackets for him.
    1994 GS FYI
    DSM/CSM Manuals
  17. #217
    06-16-2010
    Fort Mill, SC
    2,282
    I would love one, lemme know if you need my car for R&D
    "If one day the speed kills me, do not cry because I was smiling"
    -Paul Walker #rememberthebuster
    -Andrew
  18. #218
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by DTP View Post
    We'll see! I might start on it mid September.
    1994 GS FYI
    DSM/CSM Manuals
  19. #219
    08-18-2004
    Charlotte, NC
    1,029
    A little update:
    If anyone remember awhile back in a post I mention about creating a hybrid MAF using the #011 honeycomb with the #482 airhorn? Well anyway, I try using the #482 airhorn on the #501 MAF and the ECU/engine HATES it. The car runs as it had a misfire and running lumpy. So I switch back to the original airhorn for the #501. The #482 airhorn/MAS isn't meant to run on a NA I4 without sometype of compensation. The #011 and #501 MAS can run on a 7G with a little readjustment of the TPS and BISS screw.
    So what I gather up is this: The #011 MAS flows a tad more than the #501 while the #482 and #399 outflows the #011. I have decel stalling issues with the #011 but thats when I was running the 6G74 TB and Cyclone Manifold, I still have the #011 mesh so I will try that over the weekend. The #501 and #011 MAS are identical on the outside and the other noticeable difference is that the #501 has a metal honeycomb mesh while the #011 has a plastic square mesh.
    1994 GS FYI
    DSM/CSM Manuals
  20. #220
    12-13-2010
    Brooklyn, Maryland
    4,643
    I love how you try different parts combos to make what you need and document what you learn as you go. Shit's dope Jamie, keep up the good work, even if you never hear too many praises about it.
    -Greg
