Thread: mysticj's 2011 Build
Page 12 of 14 FirstFirst ... 2891011121314 LastLast
Showing results 221 to 240 of 262
  1. #221
    08-18-2004
    Charlotte, NC
    1,029
    I love how you try different parts combos to make what you need and document what you learn as you go. Shit's dope Jamie, keep up the good work, even if you never hear too many praises about it.
    Thanks! I really appreciate your comment.
    1994 GS FYI
    DSM/CSM Manuals
  2. #222
    08-18-2004
    Charlotte, NC
    1,029
    So a few guys ask about a price for the rear chassis brace, which at first I was against the idea of having "some" made. So far there are like five guys interested, keyword interested, so I am going to get quote from the metal shop on supplies and etc.
    1994 GS FYI
    DSM/CSM Manuals
  3. #223
    Awesome!
    1994 Galant GS - Daily driver
    1994 Galant LS - Parts car
    Garage: http://www.thegalantcenter.org/garag...iew-20241.html
  4. #224
    Yeah... let us know.
  5. #225
    08-18-2004
    Charlotte, NC
    1,029
    hello
    1994 GS FYI
    DSM/CSM Manuals
  6. #226
    08-18-2004
    Charlotte, NC
    1,029
    Clean up inside the throttle and add a closed throttle switch(idle) since the TPS didn't have a pin for one. This should be fine till I get a reflash ecu and cable.
    1994 GS FYI
    DSM/CSM Manuals
  7. #227
    08-18-2004
    Charlotte, NC
    1,029
    Tack and ready for welding last week.
    Got them back today.
    Trim and clean up.
    1994 GS FYI
    DSM/CSM Manuals
  8. #228
    what TB is this? size?
  9. #229
    08-18-2004
    Charlotte, NC
    1,029
    Outlander 4G64. Inner diameter is 67mm and taper down to 60mm at the blade. Its like an Evo 8/9 TB but with cruise control actuator that I remove.
    1994 GS FYI
    DSM/CSM Manuals
  10. #230
    08-18-2004
    Charlotte, NC
    1,029
    Update: Nothing much really. Need to replace exhaust manifold gasket and studs, RH CV axle, and rear brake hoses. Just drives good, need to get it tune/dyno and after that, don't know where to go from here.
    1994 GS FYI
    DSM/CSM Manuals
  11. #231
    06-16-2010
    Fort Mill, SC
    2,282
    Let's cruise then!!!
    -Andrew
  12. #232
    Yes a proper dyno tune would be great. I'd love to see your plot and the gains. Obviously we don't expect jaw dropping numbers in an N/A build but I bet it's a pretty curve with improvement across the board.
    I'm sure it's fun to drive!
  13. #233
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by DTP View Post
    Let me know. I need to get out sometimes.
    I will. I have been scoping for a reflash ecu for months at the local yards but when I add the dollar to hp, a safc or similar will be okay. The car really starting to show it age so I won't spend a lot on looks.
    1994 GS FYI
    DSM/CSM Manuals
  14. #234
    08-18-2004
    Charlotte, NC
    1,029
    4G69 baffle plate
    Outlander manifold
    Planning to reshape the dividers and add a 2-1 merge collector on it.
    1994 GS FYI
    DSM/CSM Manuals
  15. #235
    08-18-2004
    Charlotte, NC
    1,029
    Pick up a VRX steering wheel, just needs the airbag unit.
    Also pick up a 03 ECM and made a conversion harness.
    [/URL]
  16. #236
    08-18-2004
    Charlotte, NC
    1,029
  17. #237
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    It's really awesome how you research, mix and match all those different parts. Headers look great.
    4g64T 5spd
  18. #238
    Badass. I dig it. Looking forward to how it sounds!
  19. #239
    08-18-2004
    Charlotte, NC
    1,029
    Thanks! Me too!
    1994 GS FYI
    DSM/CSM Manuals
  20. #240
    08-18-2004
    Charlotte, NC
    1,029
