Thread: mysticj's 2011 Build
Page 2 of 14 FirstFirst 12345612 ... LastLast
Showing results 21 to 40 of 262
    08-18-2004
    Charlotte, NC
    1,029
    very nice
    now do a pull
    I'll see tonight if my camerawoman is up to the job.
    Nice! this has been soooo long in the making. I can't wait to see some numbers.
    Coolant temp sensor?
    are you still running the stock exhaust?
    When I had a stock GS I remember hollowing out the cat and it making damn noticable difference in power, throttle response, sound(even through the stock muffler) and top end. It was like a whole different car.
    How about one of these?
    I have coolant temp sensor, it's under the t-stat housing. yes running stock exhaust for now...working on a replacement as well as a HFC. I need to finish collecting items for my cam swap.
    1994 GS FYI
    DSM/CSM Manuals
    Is that the intake making all that noise? you need to run it into a CAI. And i can see the throttle response is pretty damn good.
    What are you going to use for a A/F control? I might jump on the tac trix cable because i want to up the redline.
    vrsexhaust.com get a 2g GST mandrel tubing kit, and a 30" 2.5" inline magnaflow muffler and a vibrant performance muffler for the back. the sound is like the car should have sounded from the factory. You will get compliments, and you will love being able to hear your music and talk on the highway without a droning exhaust.
    Best exhaust combo hands down for our cars(any car really).
    As far as the coolant sensor i was wondering why the sensor on top of the tstat housing wasn't hooked up. thats the one i used to for my ECU like stock. Then one of the lower ones for the gauge cluster.
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by Exhaust power View Post
    yes, it's sucking alot of air...planning to add a 3" flex tube to the front.
    I'll look in the exhaust setup you mention John
    1994 GS FYI
    DSM/CSM Manuals
    08-18-2004
    Charlotte, NC
    1,029
    Sneek Peak
    1994 GS FYI
    DSM/CSM Manuals
    sweet. Do i hear a idle video soon?
    08-18-2004
    Charlotte, NC
    1,029
    Hopefully within two months
    1994 GS FYI
    DSM/CSM Manuals
    Member RacerX4g64S's Avatar
    03-13-2008
    Outside of Philly PA
    139
    Where did you find the gasket for the cyclone intake???
    11-29-2009
    Chadds Ford, PA
    2,768
    I am confused i see a trubo manifold form the looks of it, and then a header? whats the plans
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by RacerX4g64S View Post
    Didn't...ultra black RTV
    Converting the manifold for NA duties. Got it dirt cheap, just need some rewelds in the collector section.
    1994 GS FYI
    DSM/CSM Manuals
    08-13-2008
    Waterbury, CT
    3,331
    damnit y cant i see your pics anywhere!!!
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    08-18-2004
    Charlotte, NC
    1,029
    I don't know why you cannot see my pics. :(
    1994 GS FYI
    DSM/CSM Manuals
    08-13-2008
    Waterbury, CT
    3,331
    i can see them on my iphone. i just looked. good work man keep it up
    2014 Lancer Evo GSR
    08-18-2004
    Charlotte, NC
    1,029
    Looks like I'm installing cams this weekend...water pump shaft broke!!! LOL
    1994 GS FYI
    DSM/CSM Manuals
    08-18-2004
    Charlotte, NC
    1,029
    Bitchin'!!!
    1994 GS FYI
    DSM/CSM Manuals
    Awwwwww i want vids, and dyno's and to drive it.
    08-18-2004
    Charlotte, NC
    1,029
    No vids right now but I have pics.
    1994 GS FYI
    DSM/CSM Manuals
    08-18-2004
    Charlotte, NC
    1,029
    1994 GS FYI
    DSM/CSM Manuals
  19. #39
    08-18-2004
    Charlotte, NC
    1,029
    Well, remove the stock cat & install a test pipe...I need a muffler as the stock one is becoming past it's prime. Going to do some logs tomorrow and probably the whole weekend as I will be gathering data for the Eprom ECU.
    1994 GS FYI
    DSM/CSM Manuals
  20. #40
    why ont you share how you do this^
