Thread: mysticj's 2011 Build
Page 3 of 14 FirstFirst 123456713 ... LastLast
Showing results 41 to 60 of 262
  1. #41
    08-18-2004
    Charlotte, NC
    1,029
    I will
    1994 GS FYI
    DSM/CSM Manuals
  2. #42
    what are you gonna do with the stock G stamped cams
  3. #43
    08-18-2004
    Charlotte, NC
    1,029
    They have been used for the Delta regrind cams already. Right now, I have the Hyundai cams in the garage. Working on getting the Evoscan parameters right for the GS ECU.
    1994 GS FYI
    DSM/CSM Manuals
  4. #44
    According to ECM Link, the Evo 1-3 and RVR ECU have very slow BAUD transfer rate. The slowest of all other DSM ECUs and thats why they cant be logged. There's a jumper there that needs to be moved in order for the ECU to be logged. I am assuming that after the jumper is put in the correct position, the ECU will be able to be logged with Evo Scan
  5. #45
    08-18-2004
    Charlotte, NC
    1,029
    slowest to log and longest to connect if using the Hybrid feature and can only log about a max of three parameters. I'm using Evoscan 2.7 using the MUTIII protocol since I can't connect using the Hybrid protocol but the Hybrid protocol contains the correct addresses to contain accurate info from the ECU.
    1994 GS FYI
    DSM/CSM Manuals
  6. #46
    this
  7. #47
    08-18-2004
    Charlotte, NC
    1,029
    That's a lot of work. The cable I build allows me to log. I try Evoscan 2.5 using Hybrid...didn't connect but try Mitsu protocol and connects within 5 secs. Pretty fast.
    1994 GS FYI
    DSM/CSM Manuals
  8. #48
    08-18-2004
    Charlotte, NC
    1,029
    Nice! this has been soooo long in the making. I can't wait to see some numbers.
    How about one of these?
    Where sir, should I mount this thing?
    Also, I pick this up...a 3G MAS
    1994 GS FYI
    DSM/CSM Manuals
  9. #49
    Nice so whats the point behind using the 3g eclipse maf?
  10. #50
    08-18-2004
    Charlotte, NC
    1,029
    Quote Originally Posted by Exhaust power View Post
    It flows ~25% more air/less restricted than the 2G MAS.
    1994 GS FYI
    DSM/CSM Manuals
  11. #51
    05-03-2007
    Socal/Central Coast
    3,803
    I guess the 8G and 3G didn't have the same MAF? mine looks nothing like that lol
  12. #52
    mine looks like that
  13. #53
    can you flash with this cable?
  14. #54
    05-03-2007
    Socal/Central Coast
    3,803
    maybe it is the I4 MAF that looks different? Mine actually has honeycomb shapes lol
  15. #55
    oh snap, lol mine has honeycomb shapes too... (facepalm)
  16. #56
    08-18-2004
    Charlotte, NC
    1,029
    No, not the one I build. But if I can build one for the 01+ ECU w/o being expensive, I will let you know...
    1994 GS FYI
    DSM/CSM Manuals
  17. #57
    can you disable error codes from popping up?
  18. #58
    08-18-2004
    Charlotte, NC
    1,029
    with evoscan, yes....when plug into the car but not without. Is it the 43 code: EGR?
    1994 GS FYI
    DSM/CSM Manuals
  19. #59
    yes indeed, plus i want to delete the entire evap system and clean up the engine bay
  20. #60
    08-18-2004
    Charlotte, NC
    1,029
    i'm going to try using a resistor to simulate the correct voltage for the EGR temp sensor for the ECU. Do you know what the parameters are for a properly functional EGR system.
    1994 GS FYI
    DSM/CSM Manuals
