Thread: mysticj's 2011 Build
Page 7 of 14 FirstFirst ... 34567891011 ... LastLast
Showing results 121 to 140 of 262
  1. #121
    08-18-2004
    Charlotte, NC
    1,029
    Need to ditch those seatbelts. thats at least 6 lbs with the cam lock reels and all.
    Also, the stock GS seats are heavy. You need to track down some evo recaros.
    I'm working on something about those front seats.
    1994 GS FYI
    DSM/CSM Manuals
  2. #122
    08-18-2004
    Charlotte, NC
    1,029
    Install a smaller battery and pictures of the AC system remove.
    1994 GS FYI
    DSM/CSM Manuals
  3. #123
    Is that lawnmower battery getting it done?
  4. #124
    08-18-2004
    Charlotte, NC
    1,029
    Every fucking time...even in cooler temps, like say, mid 40's. Should have it tie down this weekend and hopefully find a spot to mount the 2G turbo air box.
    Still need to remove more weight...laziness preventing me from removing the power windows and sunroof.
    1994 GS FYI
    DSM/CSM Manuals
  5. #125
    08-18-2004
    Charlotte, NC
    1,029
    1994 GS FYI
    DSM/CSM Manuals
  6. #126
    11-18-2009
    Buffalo, NY
    1,758
    ITB's!! Awesome!!
    - Chris -
    DRL Delete
  7. #127
    Oh snap, are you running speed density dude?
  8. #128
    Wtf and wtf did you get itbs? lol
  9. #129
    08-18-2004
    Charlotte, NC
    1,029
    1994 GS FYI
    DSM/CSM Manuals
  10. #130
    06-13-2008
    Bronx, NY
    2,606
    From what car u got that
    SOHC Turbo
  11. #131
    08-18-2004
    Charlotte, NC
    1,029
    Which part, the fuel rail or throttle bodies?
    1994 GS FYI
    DSM/CSM Manuals
  12. #132
    08-18-2004
    Charlotte, NC
    1,029
    It's best to use Alpha-N tuning for ITBs as the Speed Density doesn't do the job that good. There is no reflash ECU capable of doing Alpha-N tuning so air plenum with a 3G MAS will be use, with a SAFC use for fine tuning.
    1994 GS FYI
    DSM/CSM Manuals
  13. #133
    06-13-2008
    Bronx, NY
    2,606
    The tb's
    SOHC Turbo
  14. #134
    08-18-2004
    Charlotte, NC
    1,029
    The tb's
    Gixxer
    1994 GS FYI
    DSM/CSM Manuals
  15. #135
    08-18-2004
    Charlotte, NC
    1,029
    New MAS and Toyota 315cc injectors
    Some 16" rims with P215/55R16 tires.
    1994 GS FYI
    DSM/CSM Manuals
  16. #136
    08-18-2004
    Charlotte, NC
    1,029
    Almost four months remaining and I need to wrap a few things up:
    Interior
    [] Remove GS seats for Celica seats
    [] Remove sunroof, cover existing hole
    [] Gauges: Water and Oil Temp, Oil Pressure
    Exterior
    [] Paint roof
    [] Replace hood
    Engine
    [] Install 2G oil cooler
    Brake/Suspension
    [] Avenger/Sebring 15mm rear sway bar($20 less than the 8G sway bar kit)
    [] Two piston brake calipers
    [] GVR4 brake rotors
    [] Replace rubber brake hoses
    Tuning
    [] WBO2
    [] 1G Eprom ECU
    1994 GS FYI
    DSM/CSM Manuals
  17. #137
    08-18-2004
    Charlotte, NC
    1,029
    Making an extension harness for the RVR ECU.
    Also planning on revising my COP setup.
    1994 GS FYI
    DSM/CSM Manuals
  18. #138
    Ugh.... converting from a gs ecu to the 1g was such a blast.... (-_- )
    I printed out an alldata sheet and made a master key for the 7g to 1g spliced harness. I used electricians wire labels to numerically label every wire for both harnesses. I still have that printout and I use it all the time. Its important that you know each and every single wire in your harness. For both cars.
  19. #139
    TGC Regular foxbrand's Avatar
    06-18-2011
    chicago suburbs, IL
    600
    I may have to make a road trip just to see your car in person
  20. #140
    08-18-2004
    Charlotte, NC
    1,029
    LOL...the RVR and GS ECU are practical the same. Making the harness just would allow me to add a piggyback ECU as well of diagnostic ease. I use the connectors from a Mirage and repin it to match the GS ECU harness then it like doing a 2G to 3G MAS harness. Straightforward.
    1994 GS FYI
    DSM/CSM Manuals
