Evo style COP, just need a bracket. Eliminate the external power transistor, so much better than the last setup. The car just wants to accelerate.
1994 GS FYI
DSM/CSM Manuals
1994 GS FYI
DSM/CSM Manuals
Sounds sick!
1994 GS FYI
DSM/CSM Manuals
Really nice man. Great stuff.
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
Finish up the bracket and clean up the wire a bit.
1994 GS FYI
DSM/CSM Manuals
Planning on something different in 2013...
1994 GS FYI
DSM/CSM Manuals
whats the sensor to the left of the oil cap?
1994 GS FYI
DSM/CSM Manuals
I think I'm going to focus on more weight reduction and chassis stiffness. I also need to replace the oil pan and rear trans mount.
1994 GS FYI
DSM/CSM Manuals
What do you mean by not having external power transistor? What am I missing here?
On the DSM/GS setup there are the coil packs and the transistor, on the Evo coils the transistor is part of the coil itself.
2014 Lancer Evo GSR
oh rly? Thats good to know. Thanks
1994 GS FYI
DSM/CSM Manuals
you care to share the diagram of the coilpacks/tach sensor and w/o the power transistor? Id like to try something like this
That would be one of the few unwomanly pieces of architecture I could stare at for hours and be happy about. ITB's look GOOD. Not sure how much you're into sharing but the I'd love to know more about the setup.
Sure, Any 8G Galant/3G Eclipse, etc ignition wiring diagram. Just need to cut and splice a new connector in place of the external power transistor. Sonata/Optima coils for the OE 7mm plug wires.
Sure, I didn't mind sharing...I'm not looking to make a profit. :)
Suzuki GSXR600 Throttle Bodies
Length- 83mm
TB Blade- 38mm
TB Outlet- 40mm OD
TB Opening- 45mm OD/42mm ID
TB Boot- 37mm x 30mm
TB Boot Height- Approx. 25mm
Fuel
Primary
1998 Sonata 4G63 Composite Fuel Rail
93-95 2JZ N/A 315cc Fuel Injectors
Secondary[Optional]
Fuel Rail- Kia Optima Composite Fuel Rail
Injectors- Saab 900/9000 Turbo 350cc Saturated
1994 GS FYI
DSM/CSM Manuals
Thats pretty sick are you going to leave them open? or build a manifold housing like the 4age?
1994 GS FYI
DSM/CSM Manuals
Oic well its good to see some performance fabrication!
