Thread: Fog Light Options
Showing results 1 to 10 of 10
    Fog Light Options
    Hello all, I am looking to change my fog lights to a yellow bulb. Ive looked at quite a few on ebay that are really affordable. It says theyre a 37.5 watt bulb. Would this be an issue? I know I should go with HID but price wise its not really an option at this point. Just want to have a yellow fog that will produce the same light output while giving it the yellow look. Any suggestions?
    11-29-2009
    Chadds Ford, PA
    2,768
    i have heard the 3000k ebay bulbs arent bad for light output.
    Those are HID or just the standard halogen that are tinted yellow glass?
    04-01-2008
    Tempe, Arizona
    1,996
    DDM tuning HID are like 30 bucks.
    TGC Regular P'NOYcaL's Avatar
    10-23-2009
    Bergenfield, NJ
    504
    ^^ x2 at least theyre 100% legit for 30 bucks.
    ________________________________________
    -RON
    11-29-2009
    Chadds Ford, PA
    2,768
    Now i was thinking the same thing, but with the constant heat of HIDs, could melt the fog housing right?? I ran my fogs off the runnning lights, and leave my running lights on all the time, so basically whenever i drive they are one. Would the housing still melt??
    04-01-2008
    Tempe, Arizona
    1,996
    they could, it kinda depends on your usage. If your using them as running lights I would not get HID's, that is a lot of heat all the time.
    11-29-2009
    Chadds Ford, PA
    2,768
    http://cgi.ebay.com/ebaymotors/YELLO...ht_1829wt_1165
    OP i found these ones, and they would be a great upgrade, they are 55w which is brighter than the 37.5w
    I had those in my 8g they were great for output and looked good for running lights.
    11-29-2009
    Chadds Ford, PA
    2,768
    i am ordering mine tonight.
