Thread: 1999 Galant V6 Thottle Body!!!!
Showing results 1 to 7 of 7
    v6 galant guy
    Icon8 1999 Galant V6 Thottle Body!!!!
    which one's do you guy's have is there an aftermarket one that will fit and make more power...i think i mite need to clean mine because it's idleing really bad when i stop at a red light or if i turn on my heat it dips really low almost to the point were the car mite just shut off....help please thanks...
    it sounds like your idle air control valve is going bad.
    04-01-2008
    Tempe, Arizona
    1,996
    I believe the 6g74 TB will work.
    v6 galant guy
    how do i fix that?
    i am not really sure i have never had to replace one.i have heard about what happens when they are going bad though.
    v6 galant guy
    damn thanks bro
    the idle air control valve is attached to the throttle body.the only way to fix it is to replace it.
