Thread: Stuck Timing Belt Sprocket Bolt
Showing results 1 to 20 of 21
    NEWBIE
    12-23-2008
    Jackonville, Florida
    31
    So I went to replace my timing belt and well the bolt is stuck. I had a 3ft. breaker bar on it and only managed to damage the hole that is used with the special tool that I don't have to keep the sprocket from turning. Any ideas on how to break it loose and to change the timing belt. I'd rather not return all the belts. They need to be replaced.
    did you try putting the breaker bar against the body and cranking the engine over a couple times.that usually works.
    NEWBIE
    12-23-2008
    31
    No I read that is a possibility. I am just afraid I'll break the bolt. Should I heat it up with a torch and then try and crank it over?
    yeah you can try that.
    did you try a impact gun on it too?
    NEWBIE
    12-23-2008
    31
    Dont have a impact gun available to me. All I had was the breaker bar. Didn't work very well because I couldn't secure the sprocket so it would stop spinning when I tried to loosen bolt.
    Side note. Should I replace my water pump while I have it all torn apart?
    06-16-2010
    Fort Mill, SC
    2,282
    I think you might be able to rent one from autozone
    Yes! Replace it now
    -Andrew
    NEWBIE
    12-23-2008
    31
    Well what is a way to secure the sprocket? If I could secure that I could use the breaker bar. Though I'm tempted to try turning the engine over. I'm am just a bit scared I'll break something.
    put it against the wheelwell and just crank it but only crank it for a couple of seconds
    NEWBIE
    12-23-2008
    31
    I was thinking of letting it kinda slam into the the ground maybe 6 inches off the ground to kinda jolt it loose? Bad idea or no?
    Side note: Autozone replacement waterpump ok brand?
    i would try the wheelwell first so it wont move.autozone waterpump is a ok brand but other people would recommend dealer parts.
    you want even pressure on it others wise it could break.
    NEWBIE
    12-23-2008
    31
    Gotcha good point about the even pressure. What about heating it up a bit before cranking?
    Well I'm getting decent belts, new pulleys. The new pump is only 32.99 right now at autozone. Which is pretty good price. Hard to pass up.
    yeah try and heat it up until it is orange and put it against the wheelwell and then crank it over for a couple seconds and see if it broke loose
    if you cant break it free by hand what makes you think the starter will break it free? Impact gun or start hitting the gym!
    04-02-2009
    Denver Colorado
    1,447
    You will likely need to heat up the crankshaft pulley bolt a bit with a torch. You can try using the break bar after it has been heated, but ultimately the heat and Impact combination will work.
    Both the 3.0L and 3.8L engines I have removed the stuff on required a lot of heat from a torch and a 1/2" impact gun
    www.blackheartmotors.net
    NEWBIE
    12-23-2008
    31
    Thanks for all the advice, I'll give it a go this weekend hopefully. Maybe take over someone's garage this weekend that has an impact gun to ease the process. Plus I'm not sure if my belt will get here in time. That will be the determining factor. Returning my Autozone belts and ordered some Gates belts. Read some about the Autozone belts and consensus was they aren't too hot a choice at least for replacement Timing, so went and replaced all with Gates.
    yeah i have heard people saying to go with mitsubishi timing belts or gates because people have used the autoparts belts and they cracked at 20,000 miles.
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    Not sure this works on an A/T but on an M/T you can just put the car in gear and have someone step on the brakes.
    Otherwise you can take a straight section of sturdy steel, drill a couple holes in it for bolts to go through and use that as a pulley stop. Just have one end against the ground and the bolts going into the holes on the pulley. You might need to cut a little relief section for the center bolt.
    I've found that on really tight stuff I have better luck with a long breaker bar than I do with an impact. I'm just using a Dewalt 18v cordless though.
    Quote Originally Posted by eclipsh View Post
    you have some good ideas there.
