Thread: speedometer swap
Showing results 1 to 4 of 4
    speedometer swap
    Hi!
    I have a galant 1999 2.5 v6 manual european, and I want to change speedometer from a galant 2000 2.5 v6 manual also european. But it has an electronical odometer, but mine hasn't.
    Is it possible to change speedo's, I know that the 2000 would fit, but will everything work properly? Most of all I'm worrying about the odometer.
    Waiting for your opinion.
    06-16-2010
    Fort Mill, SC
    2,282
    That post is spam my friend. The best I can tell you is to look at both of the connections in the back to see if they are the same.
    I wish I knew more, but we have different set ups than yours. Good luck!
    -Andrew
    07-12-2007
    SoCal
    4,632
    Try searching this topic in this section:
    https://www.thegalantcenter.org/forumdisplay.php?f=84
    I think Ive seen it discussed there before. If not try posting your question there... GL
    JDM Zenki Conversion
