Thread: projector headlights? fog lights?
Showing results 1 to 4 of 4
    What's up guys. I got an 07 galant es. Was wondering if I have the projector headlights or not. Or how I can tell if I do. And also. Some people have told me my fog lights are H10s and a couple people have told me H1. Any input is appreciated. Thanks in advance.
    Zack
    ES doesn't come with projector heads. dunno about the fogs tho. Check online or the book where you buy replacement bulbs. GL=)
    10-05-2008
    Grand Rapids Michigan
    1,141
    as far as I know there are no after market projector headlights, but some earlier model GTS's came with a Halogen projector lo-beam, Reflector hi-beam set up. If you want to do a little work there is also the Morimoto Mini Projector (available in h1/D2S) that you can slide into your OEM dual filament headlight with minimal effort.
    http://www.theretrofitsource.com/pro...e80d1065e3a225
    10-05-2008
    1,141
