Thread: wheel size
Showing results 1 to 13 of 13
    wheel size
    Hallo
    I am new to the forum and can not be found to my problem. I wonder what the maximum offset and the rim width can give to my galant year 2001.
    sorry to my bad english
    the maximum offset you can go with is 45 and a maximum width of 8 inches.
    BS. I am running an 8.5" wheel and it fits, doesn't rub.
    there isn't a max offset max width. its a combination. of the two. For example, A 8.5" wheel with a +20 offset will rub on the fender, but a wheel with a +50 offset will rub on the suspension components, and then a wheel with a +38 might not rub at all.
    Quote Originally Posted by pinoyesv6 View Post
    ok i thought it was same as a 7g galant but i guess not.and yeah you do have point there about the combination.
    im running 18x8 in the front and 18x9 in the rear, +38 0ffset no rub
    Nobody built like u, u desighn ur self.
    5spd swap
    full custom body conversion
    18x9 Works VS
    Big 16g evo3T next project
    Quote Originally Posted by Miran View Post
    Hallo
    What are you trying to accomplish with the car? What is your budget?
    I want to put on rims 18 or 19 inch. I would not like roll fenders
    06-13-2008
    Bronx, NY
    2,606
    Sorry buddy. If you go with 18 or 19 I will recommend rolling the fenders. It depends the rim offset and tires settings you get. Don't go above 18.
    SOHC Turbo
    You can run 18x7.5 +40mm to +45mm offset with either 215/40R18s or 225/40R18s without issues.
    Now I got 17 inch, ET38, 7,5J
    foto
    05-02-2008
    Hacienda Heights, CA
    3,014
    i had 19x8.5 +46 with shaved fenders. but i donno if USDM offset would be different with your car though
    So then 18's on my 8g wont rub or nothing?
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    I ran 19x8 with +40 offset with 225/35-19 tires with no rub at all and I'm lowered.
