adjust the rod on the clutch master more toward the floor, it has a lock nut so loosen that before u pull out the pin that holds the rod to the pedal then spin the end of the rod clockwise to shorten it. dont go too far just a couple turns. these cars 7Gs/2gs need extra clutch pedal free play or go into a pump up mode as well and that leads to clutch slippage
check the slave is getting full travel when you hit the clutch as well as maybe its the master or slave acting up
i hope its not the clutch.
