Thread: Changing O2 Sensors
Page 2 of 2 FirstFirst 12
Showing results 21 to 26 of 26
    The 95 S model I just parted out had two O2 sensors. The opening for the O2 sensor under the seat was located slightly behind the driver's seat front left mounting bolt. If you slide the seat to its rear most position you might be able to feel the wiring where it passes thru into the car.
    While I did not try this personally because I was parting out the car, I believe you could access the connector for the under the seat O2 sensor without having to remove the floor carpeting. Remove the driver's seat (four bolts) and then the center console. With that done I believe you could reach the connector thru the opening in the carpeting that the transmission shifter and the parking brake poke thru.
    jjj
    North Bay...NorCal
    2,552
    ^^^Nope...not in this case. But its good to know for the next G I get (if ever lol) of where to look
    North Bay...NorCal
    2,552
    So got both changed out...it was definately needed!
    Sensor 1
    Sensor 2
    so was that the reason for the fail emmissions
    Nobody built like u, u desighn ur self.
    5spd swap
    full custom body conversion
    18x9 Works VS
    Big 16g evo3T next project
    it has been running lean
    Lean = lots of NOx
    North Bay...NorCal
    2,552
    Quote Originally Posted by Predat-R View Post
    Not sure...going to try to smog it tomorrow morning
    Lean = lots of NOx
    Well I hope that the new sensors help even things out a little. Like I said the only issue now (with it running) is its bogging a little like when I am partially driving...maneuvering into the garage and shit
