Thread: HID question
Showing results 1 to 3 of 3
    BlackBeauty
    Icon5 HID question
    07 SE Just installed JDM 9007 BI-xenon sys.
    So why does my left high beam look lower than my right high beam and the low beams are perfectly aligned?!
    It almost the same hieght as the low beam. Beyond frustrated!!!!!!!!!
    Member SirSaula's Avatar
    11-20-2010
    Dallas, Texas (Lubbock)
    286
    Did you use a relay?
    9th Generation Mitsubishi G
    TGC Texas Chapter
    Friends don't let friends drive stock. Ever
    11-20-2010
    286
    Also did you disable your DRLs?
    TGC Texas Chapter
